climate control
how would a kid like me replace the hot/cold switch? it broke last night when i was messing with the dash, when it broke it was set to hot, so now it just blows hot air if i turn the fan on, i needa get that fixed
i still wouldnt know how to take it out haha, they say you gota remove the stereo? can you show me which screws and the order of how to get it out
Don't touch the stereo lol...
Pop out the hazard light switch and defroster light switch by prying the bottom of the switch. Behind each switch is a phillips head screw holding it in(2 in total).
While gently pulling out the climate control you have to unhook the metal wire from underneath the climate control.
the climate control isnt gona come out unless i remove the cluster bezel right? after taht just lift the climate control up and theres a metal hook?
Cluster bezel? After removing the 2 screws it should be easy to slide out...bezel for climate control will be extremely loose but I don't remember it falling off.
Yes, metal hook underneath climate control unit...snapped in very tight and you probably will cut yourself.
blasterman87
Aug 18, 2009 11:11 AM
