chipped ecu's?
Old May 24, 2011 | 06:22 PM
jmarquardt0221's Avatar
Default chipped ecu's?
i have a 91` integra b18 turbo setup. Im thinking of buying a chipped ecu from rich tuning. he says that by me telling him my set up and all that is done to it, that he can create a chipped ecu and send it to me for 185.00 shipped. of course its obd1 and i have converted my car over to obd1 so it should be a plug and play. let me knw if this is a good idea or not. Or is it better to go with a dyno tune? im leaning more toward a dyno tune because of the diff. baro pressure changes, sea level etc. let me know
Old May 24, 2011 | 06:32 PM
TotalKhaos24's Avatar
Default Re: chipped ecu's?
Do the dyno thing its safer and get a good local tuner that specializes in hondas even if you have to take the car to another city in your state its defently worth it in the long run. Dont take the chance of a unknown chipped ecu and have a dead spot on the tune and blow all your hard work and money.
Old May 24, 2011 | 07:42 PM
dc4ok's Avatar
dyno is pricey. id try hitting up jun or hondata. but definately dyno
tops it all
Old May 24, 2011 | 09:36 PM
racebum's Avatar
1. if you value your engine starting you will never drive a car with a turbo strapped to it without an actual tune
2. mail order tunes are ballparks and should be finalized by a local tuner who can datalog and actually make the car run right
3. questions like this will get better feedback in the forced induction forum
Old May 24, 2011 | 11:36 PM
mouab18c1's Avatar
First of all if you're sticking with an obd1 Honda Ecu for tuning, then you'll need a chipped ecu no matter what. The basemap is just for you to start the car to check for leaks,etc and get it to the tuner.
A tune is a must on any modified motor. So the answer is you'll need both. There are other options as well. Chris at Xenocron.com may be able to help you out.
Old May 25, 2011 | 03:17 AM
Im going to stick with the tune on dyno. Its not the expensive either. I have a tuning company called big three racing that's chipping the ecu and dyno tuning for 650 out the door. I believe its a good price and its local. But yea thanks for the feed back, the only reason why I asked is because I had the greddy turbo kit and blue box on my 99 gsr and tuned it on the dyno. Ran like crap until the tune because the blue box was base mapped in cali and im in ohio. Big change it weather conditions, and parameters.
Old May 25, 2011 | 03:20 AM
This is my first da build on obd 0 so I wanted to do it right. The tuner said I should put out 275-325 hp to the wheels. Im pumped.lol I will post pics soon
Alexpbnj
Engine Management and Tuning
May 10, 2011 04:54 PM
Tomdata
Southern California
Mar 25, 2011 11:04 AM
twistedintegra707
Oct 15, 2006 10:40 AM
alfaaay
Jul 30, 2004 01:18 AM
94vtecmn
May 6, 2003 12:31 PM
