Chipped ECU vs AFC?
Old Jun 15, 2001 | 09:16 AM
HX_Guy's Avatar
Default Chipped ECU vs AFC?
In order to lean out my idle but still provide plenty of fuel for my rest of the powerband I need either a chipped ECU or an AFC...what do you guys suggest and for what reasons?
Old Jun 15, 2001 | 10:31 AM
TRuST's Avatar
Default Re: Chipped ECU vs AFC? (HX_Guy)
If you just need to make fuel adjustments a V-AFC, would be a better solution than a ECU. I would only go to a chipped ECU, if I needed to raise the fuel cutoff and or change the ignition timming maps.
Old Jun 15, 2001 | 10:44 AM
ATYPR's Avatar
AFC
Old Jun 15, 2001 | 11:23 AM
HX_Guy's Avatar
Default Re: Chipped ECU vs AFC? (FUCATYPR)
From reading the ApexI site on the S-AFC it appears to say that fuel can be adjusted +/- 50% but from 1000+ RPMs.
Does this mean that the idle fuel cant be managed since the car idles at 700 RPMs?
Old Jun 15, 2001 | 12:24 PM
stretracr's Avatar
afc unless you want to raise your rev limiter. Plus you can also change your settings as you add mods to your car. You can't with an ecu.
mtber
460
Nov 18, 2008 02:35 PM
mtber
Jul 8, 2007 01:30 PM
mtber
Mar 7, 2007 09:59 AM
