CHECK ENGINE LIGHT FOR TPS SENSOR (THROTTLE POSITION SENSOR)
Old Apr 19, 2004 | 08:47 PM
MassScene's Avatar
Default CHECK ENGINE LIGHT FOR TPS SENSOR (THROTTLE POSITION SENSOR)
Is it possible my car isnt as quick as it should be, because of the check engine for tps sensor I am getting?
Old Apr 19, 2004 | 09:01 PM
xteg95's Avatar
Default Re: CHECK ENGINE LIGHT FOR TPS SENSOR (MassScene)
um why not replace it and find out....and what do you mean its not as quick as it should be...
Old Apr 19, 2004 | 09:19 PM
ITR.#1446's Avatar
Default Re: CHECK ENGINE LIGHT FOR TPS SENSOR (xteg01)
my check engine light came on for the same thing.....does your idle jump up and down very fast once in a while?.....i dont think it will affect performance cause i just went to the track with my light on and ran a 14.10 with minor bolt on's
Old Apr 19, 2004 | 10:34 PM
SMZ GSR's Avatar
Default Re: CHECK ENGINE LIGHT FOR TPS SENSOR (ITR.#1446)
why would you run at the track while running the TPS code?
My beater civic's TPS sensor went out not long ago and the car ran like crap. So much so that I didn't even drive it until I fixed it.
Just fix it. Not worth pushing your car when something is messed up. Wasn't hard on my old 88 DPFI civic so i'm sure it couldn't be hard on an integra.
Old Apr 19, 2004 | 11:44 PM
Xsi's Avatar
Xsi
First try resetting your ECU, then try this: http://www.integra.orcon.net.nz/tps
Old Apr 20, 2004 | 12:09 AM
Stewie's Avatar
Default Re: (Xsi)
On some cars you have to "dail the tps voltage in". Meaning, adjust the tps until the voltage that it sends when the throttle is closed is at spec.
Old Apr 27, 2004 | 05:08 PM
MassScene's Avatar
THANKS FOR YOUR RESPONSES GUYS
cprlover
Dec 7, 2010 04:35 PM
realmike15
Honda Civic (2001 - 2005)
Nov 12, 2010 09:38 AM
team 15
Mar 13, 2007 12:00 AM
hondaeg8
May 14, 2004 10:23 AM
