check engine light P0441
Old Jul 7, 2004 | 02:26 PM
ckyguy's Avatar
Default check engine light P0441
ok i just ran that computer thing on my gsr for when your check engine light is on (i don't know what it's called), and it tells me the "Evaporative Emission Control System has Incorrect Purge Flow." so what do i do to fix this? replace purge valve? how? or does this thing just happen once in a while and go away after you start it like 40 times or so?
Old Jul 7, 2004 | 02:47 PM
gsrboi80's Avatar
Default Re: check engine light P0441 (ckyguy)
I think that might be the code for when you dont tighten your gas cap tight enough. I got a cel once right after I got gas. I wasnt able to run the code but the dude at acura told me to re tighten my gas cap and it will go away in a couple of days. It went away the next day. It hasnt happened since
Old Jul 8, 2004 | 04:11 AM
JimBlake's Avatar
Default Re: check engine light P0441 (gsrboi80)
A loose gas cap should throw P1456. But still, you could reset your ECM & see if it comes back.
SGarrett
Jun 1, 2017 11:59 PM
Accord-Guy
Mar 12, 2009 06:37 PM
civ05se
Honda Civic (2001 - 2005)
16
Jun 21, 2008 11:21 AM
londonsupra
Jul 7, 2006 05:30 PM
SuPeRITR
Mar 18, 2003 06:02 PM
