check engine light help
no you dont need to replace the fuse box. you may need to replace one of the fuses or fuse connections. the box is just that a box that hold electrical connections.
dude the ELD? the eld is located in the underhood fusebox. You have to replace the fusebox/eld as one unit since its built into the bottom of it. OP said he replaced the alternater and battery terminals. That shows he has a charging system problem. If hes throwing a ELD code 20 if i remeber he may either have a blown fuse or THE ELD is bad. If you knew anything about this problem integras have it with old age!.
