check engine light always on
Old Jan 13, 2008 | 09:04 AM
greenvr4's Avatar
Default check engine light always on
i have a check engine light on that wont blick but stay on if i quickly jump the key (while driving) it will turn off untill i let off the gas pedal any suggestions
Old Jan 13, 2008 | 09:10 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: check engine light always on (greenvr4)
See the Integra FAQ thread (stickied at the top of the forum) and pull the codes to see why it is on.
Old Jan 13, 2008 | 09:50 AM
greenvr4's Avatar
Default Re: check engine light always on (Dogginator)
thats the thing it wont even throw a code its just stays on i dont know if its the ecu or my ostrich
Old Jan 13, 2008 | 10:45 AM
.xcalibur.'s Avatar
are you jumping the service connector when you attempt to pull codes?
Old Jan 13, 2008 | 10:48 AM
all-mtr-teg's Avatar
Jump the service connector when the car is off but with the ignition on
Old Jan 13, 2008 | 12:18 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenvr4 &raquo;</TD></TR><TR><TD CLASS="quote">thats the thing it wont even throw a code its just stays on i dont know if its the ecu or my ostrich
Ostrich?
If you cannot jumper the service connector to read the codes, go to a local auto parts. They should read the codes for free with a scanner.
Old Jan 13, 2008 | 06:15 PM
greenvr4's Avatar
i tryed jumping it and it just stays on and nobody i know has a obd1 scanner i dont have the connector i just have a wire to ground i have a 94 gsr built head on top of a 2000 b16 block stock gsr tranny gsr ecu with a chip the ostrich 2.0 and a swap obo 0 with the obd1 in a 89 hx hatch
Old Jan 13, 2008 | 09:56 PM
.xcalibur.'s Avatar
Dont solid CEL's with no codes mean bad ECU?
Old Jan 13, 2008 | 11:14 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: (.xcalibur.)
do you have a knock sensor? maybe your ecu isnt reading it cuz you dont have one and causing it to stay on like my buddys
Old Jan 13, 2008 | 11:54 PM
Greasemonkey75's Avatar
You don't want to ground the connector, per say. You want to take a like paper clip and jump the two terminals in the connector. I'm not sure though if you can just do that with the other program your using. Is there any other symtoms??
Old Jan 15, 2008 | 03:17 PM
greenvr4's Avatar
Default Re: check engine light always on (Greasemonkey75)
i dont have a connector i just have a single yellow wire well its seem that i tried everything it seems that i need to send it to a shop and see what thay can do i was wanted to change it to hondata and get a good tune out of it see im thinking some thing got step on or it got wet.
i also need some free downloadable gsr wire skidmatics?
Old Jan 15, 2008 | 05:37 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenvr4 &raquo;</TD></TR><TR><TD CLASS="quote">thats the thing it wont even throw a code its just stays on i dont know if its the ecu or my ostrich </TD></TR></TABLE>
X2 for WTF??? your ostrich?
Old Jan 16, 2008 | 12:43 PM
greenvr4's Avatar
when i talk about ostrich i was talking about the 28pin connector that connects to the ecu the ribbion cable and or the chip sorry about the confussion also last night i disconnected the jumper wire and ran stock gsr map started the car and had no check engine so hopefully that means i have a good ecu still or the chip wasnt getting a good connection. What do yall think
Lscivic1999
Jan 24, 2007 12:22 PM
scoobyjr56
Sep 26, 2006 06:47 AM
egturbolsvtec
Mar 15, 2006 03:20 PM
wadafa
11
Oct 3, 2002 03:49 PM
johnzm
Sep 13, 2002 02:39 PM
