Cheap HID's
Old Nov 14, 2002 | 05:00 AM
QCKGSR's Avatar
Default Cheap HID's
I have a 00' gsr and i was wondring if you can pu the hid kit from the maxima 00' and for how much, if you cant could you guys give me some ideas???
Old Nov 14, 2002 | 06:48 AM
Ricky Rojales's Avatar
Default Re: Cheap HID's (QCKGSR)
Cheap and HIDs don't go together.
Old Nov 14, 2002 | 06:55 AM
IntEGNYC's Avatar
Depends...
9006 bulbs are used for the integra Low beam...
My 95 Maxima uses 9004 bulbs.
The 2000 Maxima uses 9003 bulbs.
Not a direct fit as you can see.
Also, Integras use separate fixtures for high and low beam whereas the Maxima uses the single for high and low. IMHO, its not worth the effort to get this to work.
But that's just me talking.
Old Nov 14, 2002 | 06:59 AM
Default Re: Cheap HID's (IntEGNYC)
Try the search function for group buys and HID dealers. Look for the appropraite application to your vehicle.
Old Nov 14, 2002 | 07:13 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Cheap HID's (P)
Even the off-brand models are pretty pricey. I thought I had a good deal on some Hanabi 6000K HID's, but with tax and all, they came out to near $400. For like $20 more I could have had the Philips kit.
I don't mind too much...the Hanabi's aren't too bad.
Old Nov 14, 2002 | 08:23 AM
Duck Sauce's Avatar
Default Re: Cheap HID's (shamoo)
You can make HID's from Acura TL's and CL's, even the S2K work in a Teg.
Old Nov 14, 2002 | 08:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Cheap HID's (DC2ownz)
You would only want to use S2K HID since those are the only ones that have been mentioned that are projector housing. The newer Maximas w/ HID do indeed use separate high and low beams, but they are reflector-type housings, as well as CL and TL headlights. You have to use D2S (projector) HID bulbs, otherwise the light output will suck.
Old Nov 14, 2002 | 09:04 AM
Ferrell's Avatar
Default Re: Cheap HID's (PatrickGSR94)
you get what you pay for
Old Nov 14, 2002 | 09:10 PM
crazyfiz's Avatar
http://www.geocities.com/jvxdriver/
check out this page he has done some cool things with lights
RapeV-8
Dec 23, 2008 08:35 PM
zam
Acura TL, RL & ZDX
Nov 22, 2008 05:53 PM
AccordInTheMaking
Oct 9, 2006 01:32 AM
vgsr
Jul 19, 2005 08:57 PM
Blue Liquid
Jul 24, 2001 08:27 PM
