chasing abs codes! Code 74? Somebody help me out
Old Feb 16, 2012 | 08:45 PM
tony7626's Avatar
Default chasing abs codes! Code 74? Somebody help me out
I am throwing code 74. Solenoid R. I searched but can't find and info besides that it is inside the abs unit itself. Is this something that I can replace myself?, iff not does anybody know what needs to be replaced?
Old Feb 16, 2012 | 10:48 PM
tony7626's Avatar
Default Re: chasing abs codes! Code 74? Somebody help me out
Bump. Where is a abs guru when u need one!?
Old Feb 17, 2012 | 04:50 AM
el crapitan's Avatar
the solenoids reside inside the modulator. they are not serviceable. you can, however, check a solenoids resistance to confirm that the solenoid itself is the problem. resistance of the solenoid should be 1-3 ohms. if you get a 0 ohm or OL reading, the solenoid is no good and the modulator must be replaced
scottyyhz
Honda CR-V & Element
Dec 30, 2014 04:46 PM
iRIDEdumped
Jul 11, 2007 06:12 PM
InTeGrA B18b1
Jul 7, 2003 04:04 PM
vti-R
Dec 26, 2001 08:59 AM
