changing Trailing Arm Bushing
Old Feb 5, 2005 | 02:03 PM
92integraVTECgsr's Avatar
Default changing Trailing Arm Bushing
is it hard to change a rear trailing arm bushing???
anyone done it? any tips?
Old Feb 5, 2005 | 04:40 PM
mingbling96's Avatar
Default Re: changing Trailing Arm Bushing (92integraVTECgsr)
if you're replacing it with a stock one.. its not too bad.
You have to take off yr trailing arm... use an axle end and press it out.. and press the new one back on. Sounds easy.. but its not THAT easy.. but not that hard also.
Old Feb 5, 2005 | 06:44 PM
Dan GSR's Avatar
I've done it many times
its easy when u own a 20 ton press
Old Feb 8, 2005 | 10:42 PM
Bk2fwd's Avatar
what about changing them with energy bushing?
Old Feb 9, 2005 | 09:03 AM
95lstegman's Avatar
Default Re: (Bk2fwd)
i've heard energy = bad idea. not sure. something about perfect fitment. Mugen sells a full press-in bushing, not just a replacement for the rubber part. i think prothane or energy or something sells a similar full unit for like $120 in plolyurethane.
Old Feb 9, 2005 | 08:38 PM
Bk2fwd's Avatar
After much research, I just picked up some RTA bushings from Honda. I called Acura for the bushings and they played dumb; I had to buy the whole RTA... BS the honda guys gave me the right part at a fraction of the cost. 312 compared to 64....hmmm. I really hate the Acura dealer near me. they blow.
But the reason for the stock bushings is because the energy suspension or prothane tend to bind in the arm movement.
Old Feb 9, 2005 | 08:40 PM
Bk2fwd's Avatar
oh, the tech at honda said to burn out the old bushings. Grease the new bushings, heat up the arm and press in the new bushings. sounds easy...most likey not though. good luck!
Old Feb 9, 2005 | 09:13 PM
DA9 Integra's Avatar
WOW I hope you didn't pay 64 each for rear trailing arm bushings.
Old Feb 9, 2005 | 09:32 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bk2fwd &raquo;</TD></TR><TR><TD CLASS="quote">oh, the tech at honda said to burn out the old bushings. Grease the new bushings, heat up the arm and press in the new bushings. sounds easy...most likey not though. good luck!</TD></TR></TABLE>
no. Remove the TA assembly. SPray some PB Blaster around the bushing. With the outside of the TA facing down, press out the old bushing, sleeve and all. Clean the mating surface on the TA, flip the TA over so the outside is facing up, and then pres in the new one. I have NEVER had to use more than 1500 lbs of pressure to remove or install bushings. I've done 88 Civic Wagons to 99 GSR's.
Also, what I did for my own, was rotate the bushing in the TA to compensate for being lowered. Now, staticly, the bushing is centered at my lowered ride height!
a MUST to do on all 88+ Civics/ 90+ Tegs
Old Feb 9, 2005 | 09:34 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (DA9 Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Integra &raquo;</TD></TR><TR><TD CLASS="quote">WOW I hope you didn't pay 64 each for rear trailing arm bushings.</TD></TR></TABLE>
Yeah, same here. I paid 20 each for mine
Old Feb 9, 2005 | 09:58 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (marsbike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, same here. I paid 20 each for mine</TD></TR></TABLE>
20 each where?
I paid 40 each employee cost. Dealer cost is like 35 a piece.
Old Feb 10, 2005 | 10:28 AM
Default Re: (Evs-One)
OEM-style-Replacements can be had for 20 bucks.
I got my bushings for 100 shipped. Not a great deal, but 20 cheaper than what the dealers wanted.
Old Feb 10, 2005 | 04:15 PM
Evs-One's Avatar
Solbros Owns Me
ah, OEM "style"
The OEM ones are updated and are the EXACT same as Mugen ones. I've compared both in person....same thing
Old Feb 10, 2005 | 06:47 PM
marsbike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">20 each where?
I paid 40 each employee cost. Dealer cost is like 35 a piece.</TD></TR></TABLE>
I got mine while my suspension was being put on at King Motorsports. They got it from the local Acura dealership. Plus, I'm friends with some of the former employees there
Old Feb 10, 2005 | 08:32 PM
Evs-One's Avatar
Solbros Owns Me
I got mine while my suspension was being put on at King Motorsports. They got it from the local Acura dealership. Plus, I'm friends with some of the former employees there </TD></TR></TABLE>
but thats way below dealer costs.....kinda stupid to share costs that aren't typically found
Old Feb 10, 2005 | 08:48 PM
Cjsls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">Also, what I did for my own, was rotate the bushing in the TA to compensate for being lowered. Now, staticly, the bushing is centered at my lowered ride height!
could you elaborate on this more if possible. or you have any pics to describe it. sorry, the trailing arms is part of the teg that i haven't touched at all and im not too familiar with it.
Old Feb 11, 2005 | 04:00 PM
DpSyChO's Avatar
Default Re: (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">i've heard energy = bad idea. not sure. something about perfect fitment. Mugen sells a full press-in bushing, not just a replacement for the rubber part. i think prothane or energy or something sells a similar full unit for like $120 in plolyurethane.</TD></TR></TABLE>
Where is a good place to get the 90-93 RTA bushings?
Anyone here running the energy suspension ones?
drsab2000
Mar 1, 2013 04:48 PM
efyou999
Suspension & Brakes
10
May 28, 2010 09:12 AM
chatham
May 20, 2006 10:18 PM
effects66
Jul 13, 2005 10:34 PM
fathergoose
Sep 20, 2003 11:28 AM
