Changing out the rods
Old Mar 18, 2006 | 02:00 PM
fliptout2's Avatar
Default Changing out the rods
I am changing out the rods on my b16a blocks. I need to know if they have to be punched out or is there a hidden pin or ring somewhere. I just do not want to try to punch it out to find out that there is a pin that I just sheared off.
Old Mar 18, 2006 | 07:26 PM
Sam92Teg's Avatar
Default Re: Changing out the rods (fliptout2)
Just unbolt the rod caps and push them up thru the cylinder, but gently push them up in case there is a nasty ridge at the top of your cylinder. If you feel resistence at the top of the cylinder, you could damage your pistons or rings unless a ridge-reamer is used to remove the ridge.
I removed a piston and rod from my hydro-locked B18A at around 250K miles, and the ridge had no effect on my piston and rod coming out or going back in.
No punching needed.
Old Mar 18, 2006 | 08:22 PM
Dartanian's Avatar
Are you swapping pistons or just taking out the rod/piston from the car?
If you are looking to get the piston out, you need to have a machine shop press the wrist pin out for you.
philliedawg
Mar 1, 2008 02:30 PM
lilpastrana
Apr 21, 2007 06:00 PM
eg6madness
Apr 19, 2007 06:02 PM
Yuleluder
Feb 15, 2006 05:14 AM
fresh pizza guy
Sep 4, 2005 12:20 PM
