Changing the fuel filter
Old Aug 27, 2002 | 06:55 AM
Fez's Avatar
Fez
Default Changing the fuel filter
When should this be changed?
How is it done?
Old Aug 27, 2002 | 07:20 AM
uNF$@#!'s Avatar
Default Re: Changing the fuel filter (GSRjunky)
they say every 30k miles. i change it every 15k just for ***** and giggles.
how is it done?
you take the old fuel filter out and put the new one in.
Old Aug 27, 2002 | 07:22 AM
ragejed's Avatar
Default Re: Changing the fuel filter (Soup ****)
http://www.helminc.com
get a manual
or...open end flare wrench, take off the gas cap, and go to town
Old Aug 27, 2002 | 07:46 AM
Area57's Avatar
Default Re: Changing the fuel filter (ragejed)
[QUOTE]http://www.helminc.com
get a manual
I do mine every 20K. Remove the gas cap. The bolt(forgot the name) at the top of the filter should be loosened slowly to relieve pressure in the line(place a shop towel under the filter). Use a wrench to hold the bottom of the filter secure, and use another wrench to loosen the incoming fuel line. I also remove the fuel filter bracket from the firewall to swap filters.
Old Aug 27, 2002 | 07:48 AM
Fez's Avatar
Fez
Default Re: Changing the fuel filter (Area57)
get a manual
Thanks
redlinez_r_us
Sep 16, 2009 12:02 PM
Agent Zero
Honda S2000
Mar 4, 2008 10:08 PM
tamashi523
Dec 14, 2005 05:28 AM
handa
Apr 3, 2005 03:27 PM
MugenHonda
15
Apr 19, 2003 08:16 AM
