cat. vs testpipe
depends on OBD 1 or 2
OBD 1 doesn't care about the CAT efficiency (edit: AFAIK), but OBD2 does and it will throw a code if your cat isn't efficient (which if you don't have one it will deffinately not be efficient).
so if you have OBD2, you either have to get a test pipe that has the CAT material by the O2 bung (so that it approximates the CAT for the sensor, or do the resistor thing, you can search I am sure to find out how to properly fool your system into thinking the CAT is functioning properly without a CAT actually there, but seeing as it is highly illegal to use on the street, i am sure you are only doing this for the benefit of the track, and not having to reset your ECU after each race event, right?
[Modified by samagon, 11:23 PM 6/12/2002]
the technian said my cat convertor isn't working which is causing an exhaust leak, it makes a rattling sound whenever i hit 3500 rpm and then goes away. so if my cat isn't functioning properly is my OBD2 sending a different code to my ECU? wat does the code do? how will it affect my car? and how can i fix it when i put in a testpipe
will there be a light that comes on on my dash?
ya my friend said it mite be the a pipe too, i did bring it to the acura dealership and they said that it is the cat, *******
Dukie432
11
May 15, 2009 07:07 PM
Slowboy!
15
Dec 17, 2005 12:37 AM
T--Rex
Jul 31, 2004 02:05 PM
