cat. vs testpipe
Old Jun 11, 2002 | 10:44 AM
98DC2's Avatar
Default cat. vs testpipe
[Modified by 98lagen, 9:02 PM 6/11/2002]
Old Jun 11, 2002 | 12:03 PM
zilverz's Avatar
Default Re: cat. vs testpipe (98lagen)
if you have a heavily mod'd all motor .... a high flow exhaust .. ( highflow cat , testpipe same thing) you WILL benifit from .... backpressure is less of an issue the more powerful you make that motor
with just I/H/E you will prob not benifit much at all but if you plan to continue to upgrade past that... you will benifit more and more from having it
it will increase your exhaust note db'zz too hehe so prepare yourself
Old Jun 11, 2002 | 12:10 PM
98DC2's Avatar
Default Re: cat. vs testpipe (zilverz)
thanks for answering my question. properly
Old Jun 11, 2002 | 12:26 PM
TakaIntegra's Avatar
Old Jun 11, 2002 | 12:45 PM
GSxRated's Avatar
Default Re: cat. vs testpipe (TakaIntegra)
I'm basically I/H/E and I noticed a nice high end difference w/a test pipe.
Old Jun 11, 2002 | 12:52 PM
zilverz's Avatar
Default Re: cat. vs testpipe (GSxRated)
yea i prob should have worded it a little different ... you prob do see a little something on the high end ... but your going to be trading some low end for it .... with a high output motor your not really gonna loose anything on the low end and testpipes / highflow catz are much more benifical
as far as which to get ? there basically the same thing .. i can see straight through my highflow cat.... if i could have found a straight pipe/test pipe at the time i ordered my highflow .. i would have bought that insted... should be cheaper ...
Old Jun 11, 2002 | 01:54 PM
KC GSR's Avatar
do test pipes make your car so loud that you'll wake up the neighbors are or they only slightly louder than highflow cats? I like the price of test pipes and would like to get that if i wont get in trouble with it
Old Jun 11, 2002 | 02:37 PM
zilverz's Avatar
Default Re: cat. vs testpipe (KC GSR)
your exhaust will be significantly louder.... significantly! ... if you need to ride in stealth mode .. you def dont need one of these ... you can still keep the low deep tone through the neighborhood somewhat .. but you will have to get used to driving slower..barely having the throttle pressed.. in noise sensative areas (:
but definately gives you that loud race car sound ... and depending on what you like you may not even like it .. i have a slight buzz sound at times ... im sure the note is going to still change somewhat the more powerful i make this motor ... but when you downshift and get on it with the highflow cat.... believe me ... everyone driving on that street is gonna know your coming in a hurry
its also a good tool to let slow drivers, driving in the fast lane, know to get the F' out of the way (:
Old Jun 11, 2002 | 02:54 PM
vtec2.0's Avatar
not true - depends on the exhaust he is running. i have a test pipe on my 12:1 b20/vtec and it sounds exactly the same with the greddy sp exh.
ryan
Old Jun 11, 2002 | 03:03 PM
EagleR's Avatar
Wha are the laws and penalties concerning a test piupe in VA? Is that a concern...if you don;t mind risking it I say Test Pipe all the way.
Old Jun 11, 2002 | 03:06 PM
junglistgsr's Avatar
Default Re: cat. vs testpipe (EagleR)
test pipe in VA is like death. Especially in Northern Virginia....VA is really ******* strict with vehicle safety and emissions, in some cases (not all by far) worse than CA
Old Jun 11, 2002 | 03:50 PM
Ri5e's Avatar
Default Re: cat. vs testpipe (junglistgsr)
Emissions isn't too bad. My car passed emissions last month
And as for the test pipe, your gonna lose low end torque.. and gain top end power.
It's best if you have a pretty heavy modified car.
Old Jun 11, 2002 | 03:56 PM
zilverz's Avatar
Default Re: cat. vs testpipe (vtec2.0)
ryan
yea im sure you drug the DB meter out (: jk mannnn i guess if you a traditionally quite/restrictive exhaust initially ..or one with a silencer it might not be as noticable ...
Old Jun 11, 2002 | 04:09 PM
AzN_Flava's Avatar
awww im disjointed now... i always thought high flow cats would make the car quieter then a test pipe... by quieter i thought it would sound like stock...
i like my 5zigen on my integra right now.. its pretty quiet.. but when you step on it.. its pretty nice sounding..
i dont like cars when you can hear them from a city away...
Old Jun 11, 2002 | 04:10 PM
juniordc2's Avatar
i think if you have a cat thats on right now thats really old, it might be clogging up the exhaust, so a testpipe might seem MORE better, than it really is. but hey, its dirt cheap compared to a new cat.
Old Jun 11, 2002 | 04:48 PM
uNF$@#!'s Avatar
Default Re: cat. vs testpipe (dc2gsr94)
yeah, great idea...polluting mother earth alot more for a few whp gain .... GOTO DRIVING SCHOOL INSTEAD
Old Jun 11, 2002 | 07:08 PM
GeeSeR's Avatar
my cat converter is messed up right now and i don't want to spend the cash to get it replaced from honda. would a test pipe or an aftermarket convertor be a better choice? price is kind of an issue as well. but i was wondering if there are any oxygen sensors in the factory cats? i've got a 94 gsr.
Old Jun 12, 2002 | 08:05 AM
vtec2.0's Avatar
Default Re: cat. vs testpipe (00-0187)
actually, when i performed my swap, the header to b-pipe connection was too short, thus the emergency need for the test pipe. believe me, it isn't a perma-fix - just something to keep me on the road as i need my car to go to work.
relax
ryan
Old Jun 12, 2002 | 08:49 AM
zilverz's Avatar
Default Re: cat. vs testpipe (GeeSeR)
yes test pipe would be your best bet ... and yes GSRz have the o2 sensor in the cat .. soo your test pipe would need the o2 sensor hole ..
Old Jun 12, 2002 | 11:45 AM
iH8RICERZ's Avatar
i just took off my test pipe today cause i need to get my car smogged...my car revs slower and is quieter now. I hate it!! As soon as i'm done w/ smog...test pipe goes back on for sure!!!!
Old Jun 12, 2002 | 11:48 AM
98DC2's Avatar
Default Re: cat. vs testpipe (BustAhNutZ101)
thanks to all who dropped some words of wisdom. oh yeah, to the dude who fucked with my poll, we all know no what you like doing!
Old Jun 12, 2002 | 01:59 PM
GeeSeR's Avatar
so would i just take the oxygen sensor out of my original cat and put it in the testpipe? how many oxygen sensors are in the cat?
Old Jun 12, 2002 | 04:00 PM
IC x Prince's Avatar
New User
I have a 94 GSR would a test pipe make me throw a check light?
Old Jun 12, 2002 | 04:03 PM
iH8RICERZ's Avatar
Default Re: cat. vs testpipe (UltraGSR)
i have a 94 gsr too....no check light...just make sure the test pipe you end up getting has an o2 bung...just screw it in, plug in the harness...and bam, you got your self cheap power!
Old Jun 12, 2002 | 04:04 PM
GeeSeR's Avatar
if i heard right i think the engine light would come on if you replace the cat without putting the oxygen sensors back in, also it wil mess up your ECU. a technian told me this, can anyone confirm it?
