Cat converter question
I have a 96 gsr with the greddy turbo kit.
i also have a GReddy power extreme 2
The bolt pattern on the exhaust wont fit correctly onto the stock cat, so i was wondering if someone knows where i could buy a cat that has a stock gsr bolt pattern on one end, and a JDM gsr bolt pattern on the other end.
Any help would be great. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR »</TD></TR><TR><TD CLASS="quote">i'd bet that would have to be custom made....prove me wrong....
Yup sounds like your going to have to go to your muffler shop and get them to weld you a plate on there wit the bolt pattern
Good luck
</TD></TR></TABLE>Yup sounds like your going to have to go to your muffler shop and get them to weld you a plate on there wit the bolt pattern
Good luck
I say run open downpipe
sounds sick, thats what I plan to be doing till I can afford 3 inch piping and muffler. But in your case I would just get the custom flange welded on from a local muffler shop, like what the others have said
Ok, Custom is the choice.
I need some help on this one though. How long is the Stock CAT, and what is the bolt pattern on the Stock cat, and if anyone knows off hand what is the bolt pattern on the GReddy Power extreme 2 Exhaust. 96 Integra GSR
He needs the specs so he can make me a 3in high flow cat
i would think taht the stock GSR cat would be a little restrictive for a turbo setup. Why not just get a testpipe made for it.
I just got mine from testpipe.com.
I still need two different flanges made, you guys must not be reading the whole thing above.
My stock cat wont fit onto my new exhaust, and i need a different bolt pattern from a stock gsr exhaust side of the cat.
