CAT-BACK
Old Aug 30, 2006 | 04:27 AM
gsr_pimp88's Avatar
Default CAT-BACK
if i buy a rage header or a hytech header for my stock gsr, would i be able to use any cat-back or a special fabricated one?
Old Aug 30, 2006 | 05:18 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: CAT-BACK (gsr_pimp88)
Well , it depends on the exit diameter of the header. Once your know the diameter then you can decide on what exhaust you would like to get.
Old Aug 30, 2006 | 05:47 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: CAT-BACK (Kiniku Chunks!!!)
the flange is what matters. the diameter of the header and exhaust only restrict the flow of gas, they don't determine fit. make sure that the header has the same flange as the stock header (and has the correct dimensions) and it should fit the stock exhaust.
Driven
May 23, 2006 06:43 AM
egg_baLLa
Dec 28, 2005 10:48 AM
integerkgsr
Jan 22, 2004 10:08 AM
acatak
Aug 29, 2002 11:13 AM
