Car Starting Problems Please Help!!!
I got a problem...last night I parked my car inside the garage then I had to move it outside to park it for the night. Everything worked fine. I go outside this morning and my car doesnt start. Here's whats going on....
Radio works
headlights works
alarm works
door locks work
windows do not work
cluster shows no light when key is inserted and turned on
won't turn over
wont even click
no power to clock
no power to cluster
checked all fuses ...seems to be ok..
Tried jump starting it...nothing still nothing
tried swapping batteries from my integra to the accord
integra battery works fine in accord just fine...couldnt test if accord battery works in integra its to big to fit...
I dont have a test light...i got a volt meter i can use though to test...
what should i test though
i have power to the radio, door locks and alarm,
but no power to windows or to cluster or clock...
I was thinking about taking apart the steering column and seeing if there are any worn parts in the ignition and its not catching enough to make it to the 2nd position on the ignition when I turn the key.
Any input would be helpful??
Radio works
headlights works
alarm works
door locks work
windows do not work
won't turn over
wont even click
no power to clock
no power to cluster
No its not your main relay. Are you getting power to the starter when you turn your key? If not work your way back to the ignition and see if that is getting power. You probably have a bad ignition switch.
maybe your starters out. or else the black/white wire in the steering column is lose or isn't getting any power to it thats the wire where they do the start killed to. try push starting it may work.
skyleraustin
Apr 21, 2015 01:02 PM
thehangerman
Mar 5, 2013 03:11 PM
.adam.
Jan 3, 2012 03:38 PM
StreetRiot_DRE
Feb 25, 2008 01:36 PM
