car pulls to the left.
My car was pulling right and it was my right tire pressure was too low... and it was a gradual pull, as in it got worse as i drove on it. check pressure in all four tires even a rear tire can cause a pull to either the left or right.
if it precedes then get the alignment done.
Good luck!
when my civic did this it was due to one of the brake pistons being stuck outward. if you have a smell like a burnt clutch coming from that rim, check the inner pad
Weel alignement won't stop the car from pulling one side. Caster is the angle that cause Pulling and it can't be adjust on a Honda. Switch left tire at the right and the right at left and try the car. If pull Right, tires is the probleme, If still pull left. Table must been hit and little bent back. If you go for weel alignement ask if caster is more than 1/2degre Lower on Left than the right. If it's the case Only table that got bolt to seperate it in 2 can be shimed to fowars the weel and increas caster
EJ8VTECFTW
Honda Civic (2006 - 2015)
Jul 10, 2007 08:15 PM
CrazyHondaBoy
Oct 19, 2003 01:06 PM
Krnbk2
May 12, 2003 09:03 PM
