CAR OVERHEATING NEED HELP
Old May 28, 2011 | 03:16 PM
jlowellintegra's Avatar
Default CAR OVERHEATING NEED HELP
okay just bought a hatch with a gsr swap...the temp keeps going up and down so i changed my thermostat it now idles better and stays where it should be at temp sitting still. my oil is not milky theres no smoke im almost sure its not the head gasket or else it would stay hot? but i think my fan might now be working but it was the other day and the fuse is still good any input would be awesome!!!!
Old May 28, 2011 | 04:30 PM
Default Re: CAR OVERHEATING NEED HELP
Anyone??? I did see a little white smoke come out now after changing the thermostat
Old May 28, 2011 | 07:59 PM
mark@silbernage's Avatar
So - everything seem normal now? Temp stable, running well, fluid levels steady, no contamination evident in the radiator fluid or oil?
If so - sounds like 'mischief managed' ; ' )
Good luck
Old May 28, 2011 | 11:37 PM
Tha_liks's Avatar
Make sure fan is running... Flush your cooling system and put new antifreeze, and Check upper and lower radiator hoses for leads as well as the smaller hoses at the thermostat and the back of motor
Old May 29, 2011 | 04:32 AM
Temp is not stable n I seen a lil white smoke from tp but no contamination in oil or antifreeze but I think my water pump is out something is whining by the timing belt but why would my fan stop wrking
Old May 29, 2011 | 10:45 AM
Cereal One's Avatar
Do I need to ask if your cooling system has been bleed.
1)Buy 7 inch or so radiator funnel.
2)Remove radiator cap. Insert funnel. Over-fill radiator so that coolant/water about 1/4 of the way up the funnel. Use vice-grips to block off radiator overflow tank.
3)Start engine. Let it reach operating temp.. Let idle for 30 or so minutes adding coolant when needed. (The coolant level will raise 3/4 up or so the funnel before it drops)
4)You should get to a point where you are not adding water. At that point the water in the funnel should raise and drop from 1/4 to 3/4 depending on the "cycle" of the system. This is good! Now find a buddy and have him rev the motor at 2000RPMS for 10-15 minutes while you sit and watch for bubbles and monitor the level making sure it raises up to 3/4 of the funnel an levels off down to 1/4. There shouldn't be any bubbles.(The first time I bleed my system it took several hours because I had not blocked off the overflow tank.) Oh and you might see a million microscopic bubbles. This is because the radiator cap is not on and the system is not under pressure. Waters boiling point increases if under pressure.
5)Youtube it if this sounds like a foriegn language.
If your temps are still too high after bleeding for your liking there is a product called "water-wetter" by red-line. Basically it's an additive to the cooling system. I don't buy it but others swear by it. It's suppose to lower temps by making your coolant more "soapy" i.e. slippery
Just trying to be helpful.
Old May 29, 2011 | 03:34 PM
I did not bleed it...but I realized my fan is NOT working not sure if bleeding it would have something to do with it but there's alot of anti freeze in there not really sure how to check the fan motor with the paper clip thing??
Old Jun 25, 2011 | 12:31 PM
jp9797's Avatar
i believe u run a postive line and a negitive line to the battery my step dad did it the other day to see if my fans were working
Brent1204
Aug 18, 2015 02:09 PM
BrianDubster
Aug 18, 2011 01:45 PM
roadromper1
Honda Civic (2001 - 2005)
28
Aug 20, 2010 02:41 PM
lisajasmin
11
May 25, 2008 10:42 PM
meanTheDope
Aug 22, 2005 10:31 AM
