Can i replace this?
Old May 4, 2014 | 09:46 AM
Alcatrax30's Avatar
Default Can i replace this?
Can anyone tell me if i can replace that top cube part that has a big bolt on it ? Driver side its rusted
Old May 4, 2014 | 01:29 PM
B_Swapped93's Avatar
Default Re: Can i replace this?
I already answered your question it's part of the frame as in not removable unless you wan to cut and weld but I don't recommend that at all seeing as it hold the subframe. Take a wire brush to it and scrub the surface rust off
Old May 4, 2014 | 08:43 PM
Alcatrax30's Avatar
damn are you serious?? It dosent look like it will hold much longer i had people tell me i could take it off as in replace
Old May 4, 2014 | 08:54 PM
Originally Posted by Alcatrax30
damn are you serious?? It dosent look like it will hold much longer i thought i could replace it but the front subframe is removable is it not?
It looks solid to me seriously take a wire brush or sand paper to it then re-consider. Yes it is but it's a pain to do if you are new to working on cars
Old May 5, 2014 | 04:24 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
How is that piece fastened on that it won't come off? It looks like cast iron. Maybe it's just a spacer? You sure it doesn't come off if you remove the subframe?
OP....you're worried about that piecr not lasting. Look down toward the bottom of the picture. It's all rusted. It's all going to rust normally.
Old May 5, 2014 | 06:23 AM
Alcatrax30's Avatar
Yeah i mean most of it its all surface rust but looking at that piece im like dang but it dosent look like its part of the car or i wouldent rust that fast it look like its iron thAt comes off
Old May 5, 2014 | 06:24 AM
Alcatrax30's Avatar
What if it breaks? Yeah sounds like a pain
Old May 5, 2014 | 07:09 AM
kyden's Avatar
why do you need to replace it? it appears to just be surface rust.
Old May 5, 2014 | 07:32 AM
Alcatrax30's Avatar
Because that one piece looks like it is going to fall apart
Old May 5, 2014 | 07:35 AM
B serious's Avatar
?? The whole picture is rust. Why are you focusing on that one piece? I could see it standing out if nothing else was rusted. It's all rusted. Why do you think it'll fall apart?
Old May 5, 2014 | 07:47 AM
Alcatrax30's Avatar
Because everything else can be replaced dont know about that piece
Old May 5, 2014 | 09:49 AM
B serious's Avatar
You can check by loosening the subframe bolts a little and seeing if it moves.
Old May 5, 2014 | 11:06 AM
Schister66's Avatar
Man U FTW
Are we looking at the same picture? I dont see anything rusted through that badly...
Old May 5, 2014 | 11:13 AM
Alcatrax30's Avatar
Im going to try it later on hopefully it does movee
Old May 6, 2014 | 05:07 AM
kyden's Avatar
that piece is fine. you're overreacting.
Old May 6, 2014 | 06:27 AM
Alcatrax30's Avatar
Im looking to replace most things on the front 2 wheels and was curios if i could replace that so nothing will look rusted
Old May 6, 2014 | 07:34 AM
GagnarTheUnruly's Avatar
Those are spacers. They are separate from the subframe. You can replace them if you like, or refinish them. It looks like surface rust to me.
Old May 6, 2014 | 08:01 AM
B serious's Avatar
Sand blast and paint/powdercoat if you want to get rid of the rust for cosmetic purposes. It's a cast iron spacer. It's not falling apart.
Old May 6, 2014 | 11:53 AM
Alcatrax30's Avatar
Thank you for the reply! Thanks guys!
98b16sc
Welding / Fabrication
Apr 9, 2014 07:26 AM
self_made
Dec 21, 2004 08:00 PM
fperra
Nov 30, 2004 08:49 AM
NoLipRacen
Mar 7, 2004 05:42 PM
tbocrx
Aug 3, 2003 10:02 AM
