CAN THIS BE DONE??????????
Old Dec 14, 2003 | 12:31 AM
idontcare's Avatar
Default CAN THIS BE DONE??????????
ok i have a b18a motor....and im sure the head is warped. can i put a b18b head on it with out ne modifications.? let me know.
Old Dec 14, 2003 | 01:12 AM
90teg's Avatar
Default Re: CAN THIS BE DONE?????????? (idontcare)
yup
Old Dec 14, 2003 | 10:49 AM
mr.beeks's Avatar
Default Re: CAN THIS BE DONE?????????? (90teg)
basically the hardware is the same!!
and thats one of the best things you could do to your engine..
Old Dec 14, 2003 | 11:04 AM
Mr. Softee's Avatar
Default Re: CAN THIS BE DONE?????????? (mr.beeks)
yes, you can. you can also use the search function.
Old Dec 14, 2003 | 11:43 AM
H22A EG6's Avatar
Default Re: CAN THIS BE DONE?????????? (94goldjungsr)
wordizzel it should not be a prob yo
Old Dec 14, 2003 | 12:53 PM
jDMJeRk's Avatar
i believe you can do the same with thing with the b20 head; that head flows better then the b18a and the b18b heads from what Ive heard...dont quote me though
Mr. Softee's Avatar
Default Re: (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">i believe you can do the same with thing with the b20 head; that head flows better then the b18a and the b18b heads from what Ive heard...dont quote me though </TD></TR></TABLE>
Old Dec 14, 2003 | 12:55 PM
P1mpSlap's Avatar
If you warped the head, you'll have to mill the block to insure adequate fit/seal.
BTW: how the hell did you warp your head?
Old Dec 14, 2003 | 03:40 PM
91tegrals's Avatar
probley over heated....
Old Dec 14, 2003 | 04:45 PM
redlineintegra's Avatar
Default Re: (91tegrals)
Here's the info you need to swap a newer (94+ non-vtec) head onto a b18a.
http://www.g2ic.com/forums/sho...=7566
Old Dec 14, 2003 | 07:39 PM
random-strike's Avatar
quite true. the b20b head does flow a lot better, i put one on my car after my b18a1 head was ****'d
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">
it flows better
DA chosen 1
May 23, 2006 09:46 PM
eymnewdc4
Mar 30, 2005 06:51 PM
bambam
Apr 6, 2004 08:54 AM
88civicHB703
10
Jul 9, 2003 12:38 PM
Chuji
Sep 6, 2001 05:25 PM
