CAMS Help!
Old Jan 17, 2010 | 09:59 AM
Bsharpe's Avatar
Default CAMS Help!
Would I gain more hp off of type r cams or bullfrog cams? This is on a gsr motor with jrsc 10psi
Old Jan 17, 2010 | 03:06 PM
mouab18c1's Avatar
Default Re: CAMS Help!
the heck are bullfrog cams?
Old Jan 17, 2010 | 04:30 PM
DC40's Avatar
Never heard of them either. What are the specs? Duration? Lift, etc?
Old Jan 17, 2010 | 05:56 PM
zedron's Avatar
Same, never heard of them.
Old Jan 17, 2010 | 05:59 PM
DVDr's Avatar
Never heard of bullfrog either so did a little googling.
http://geometroengines.com/Cams/cam.html
Wich set were you thinking of going with ?
92-99 HONDA CIVIC/DEL SOL TYPE R 16V 1.6L DOHC VTEC
PART NO: HCCS13
DESCRIPTION: Good race cam.
POWER BAND 6000 RPM. to 8300 RPM.
IDLE: Good
SPECIFICATIONS: Intake LIFT - .434 DURATION - 250
Exhaust LIFT - .405 DURATION - 258
92-95 HONDA CIVIC/DEL SOL 16V 1.6L SOHC VTEC
PART NO: HCCS14
DESCRIPTION: Excellent with NOS.
POWER BAND 2000 RPM. to 8500 RPM.
IDLE: Fair
SPECIFICATIONS: Intake LIFT - .397 DURATION - 261
Exhaust LIFT - .407 DURATION - 228
PART NO: HCCS15 (For Automatic)
IDLE: Fair
SPECIFICATIONS: Intake LIFT - .405 DURATION - 250
Old Jan 17, 2010 | 06:10 PM
Bsharpe's Avatar
Thier Gude Bullfrog Cams idk anything about them... a guy was gonna use them on his jrsc
Old Jan 17, 2010 | 09:45 PM
jakobe06's Avatar
Never heard of Bullfrog Cams???
Old Jan 18, 2010 | 01:22 PM
HEADS OR TAILS's Avatar
Bullfrog cams are old skool, my homeboy used them a long time ago. They work good except idle but thats normal
Old Jan 18, 2010 | 02:01 PM
Bsharpe's Avatar
They worth 160? Do they have to have adjustable cam gears to use them?
Old Jan 18, 2010 | 02:16 PM
Yea there worth 160. U don't have to use aftermarket cam gears, but if u get it tuned, they will help
Old Jan 18, 2010 | 02:39 PM
Bsharpe's Avatar
Any aftermarket cam gears? Any one got any good ideas for cams??
Old Jan 18, 2010 | 07:58 PM
Madukes's Avatar
get a cam gear with more then three bolts. i've heard of cam gears with with three bolts that slip (AEM in preticular). so keep that in mind.
Old Jan 18, 2010 | 09:13 PM
questo209's Avatar
Alot of the bullfrog cams were regrinds and had a tendency to wear down over time. I would check the lobs on them if they have alot of use.
Old Jan 19, 2010 | 04:09 AM
Bsharpe's Avatar
Thanks guys
Old Jan 19, 2010 | 01:25 PM
wunfstgsr's Avatar
Loved
Community Favorite
You should of posted on the f.i forum under what jrsc set are you running,
first off forget about the frog cams, take my advise lht's and lots or experienced people with the jrsc and use the gsr intake cam and itr exhaust cam. http://www.ftlracing.com/tech/honda/JRSC.html. and you better tune the motor after to get the best performance. whats your setup/hp?
Old Jan 19, 2010 | 06:35 PM
Bsharpe's Avatar
Stock gsr cams stock gsr motor full exhaust 3in cold air intake tuned 252 hp
Old Jan 19, 2010 | 07:00 PM
wunfstgsr's Avatar
Loved
Community Favorite
you mean full 2.5'' 3'' exhaust?? you should ditch the 3'' cai and run a 3'' short ram or the comptech icebox, if your gonna swap cams sell me your gsr cams i need some pm me if you want. any engine managment,injectors header ?
Old Jan 21, 2010 | 11:08 AM
DAIntegra_lover's Avatar
New User
blox cams are always nice
Old Jan 21, 2010 | 12:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
have you had any dyno experience with these blox cams on a jrsc'd motor??
I highly highly doubt those cams are even suitable for a jrsc. stick with gsr in and itr ex ftw!
LS/V-T
15
Jan 2, 2011 08:59 PM
koczeka
11
Oct 14, 2006 07:27 PM
28psiBoosted
Mar 14, 2002 05:12 AM
blkDOHCsol
Jul 19, 2001 04:11 PM
