Cams!
Is the GS-R cams the same as the Civic Si Cams??
I know that the 2000-2001 ITR cams are the same as the CTR cams, but I was wondering if the GS-R and Si's have the same cams as well.... LMK-
Does anyone know if the Itr cams can handle the stock gsr valvetrain? Or it needs to be upgraded? Btw when changin out the cams. Would it be better to just change out the intake side only and keep the gsr exhaust side? Or change them both out for itr? Keep in mind I'm goin to turbo it. So would the itr cams benefit me for turbo or keep my stock gsr one? Thanks for the help.
GSR valve springs can handle ITR cams just fine.. if you want, you could just swap in the intake cam only, but unless your funds are really low, why not get both? if you're going to turbo your car, the ITR cams probably wouldn't hurt, but then again it's not really necessary. turbo GSR is fast enough on stock cams
97-99 ITR intake cam has 3 degress less duration than the CTRs, but they fixed that for 2000-2001.
GSR cams have a longer duration than b16 cams and can make for a little cheap power.
Thanks In7egrity. Guess i'l be gettin 00-01 itr cams then anyone know a good place?? How do I know if their the real itr cams that i'm gettin any descriptions or marking that I can tell? I don't want to get ripoff and how much do you think I should pay for new and used for 00-01 itr cams??? Thanks.
So if my friend swapped in some B18C1 cams in his B16A motor, will it give him gains? Is the GS-R cams bigger? Got any specs on both?
dont waste your time swapping out Si cams for GSR cams. really.
ITR or CTR cams are a completely different story though.
really, there is virtually NO market for GSR or civic SI cams.
the only buyer is someone that has a bare head and will settle for those stock cams in the time being before they get enough loot for a nice set of cams.
how else do you think I did NOT get rid of my GSR cams in the year+ that they were out of the car? I couldnt give them away!
compwc18
May 22, 2005 05:05 PM
Don't have specs or anything but I've heard on this board that there are slight gains. Very slight gains.
