camber question
Old Sep 28, 2007 | 02:05 PM
Jackson123's Avatar
Default camber question
I have a rather difficult question (maybe not for you), but recently i got into a small accident in my 94 ls, and bent the lower camber or control arm (not sure of the name sorry) it is "j" shaped and goes below the brake rotors that braces the rotors to the body. ill get a picture asap, but i wanted to know 1) what's the name of the part i speak of. 2) if the same part on that same time era civic (94-00) would work as a replacement part. Any help would be great. thanks
Old Sep 28, 2007 | 02:10 PM
hatchling37's Avatar
Default Re: camber question (Jackson123)
I think that you are talking about your lower control arm. It bolts in 2 places to the chassis and then bolts to the ball joint at the bottom of the steering knuckle. I'm very certain that Civic part will not directly bolt up to the Integra.
Old Sep 28, 2007 | 02:22 PM
Jackson123's Avatar
Default Re: camber question (hatchling37)
ok thanks, its just that there is one sitting in a junk yard by me, and they would probably just give me the part, or sell it for cheap. Ill try and get a picture tonight or soon. Any idea what the part would run for?
Old Sep 28, 2007 | 02:30 PM
In the junk yard? About 25-30 dollars. Plus an alignment.
Old Sep 28, 2007 | 02:32 PM
Jackson123's Avatar
no i mean the car was in the junkyard (civic). how much would it be at like a store or online? and would it be worth it to buy aftermarket or better ones than the OEM ones?
Old Sep 28, 2007 | 05:14 PM
Dogginator's Avatar
Daisy... Daisy...
Here is the part:
http://www.sonsacuraparts.com/...dIrno=
For used, search on http://www.car-part.com
Old Sep 28, 2007 | 07:32 PM
Jackson123's Avatar
Default Re: camber question (Dogginator)
see, i'm not even sure that's the part, a friend is storing the car for me right now. thanks for the pic by the way. would it be better to buy oem, or aftermarket?
JDMCRX
Suspension & Brakes
10
Apr 11, 2013 04:57 AM
ChevelleSSLS6
Mar 10, 2009 01:05 PM
KRock459
Feb 15, 2009 04:48 AM
LilMrTinnie
Apr 26, 2005 03:48 PM
suprmods
Aug 6, 2004 08:27 PM
