camber kits?
Old Aug 19, 2007 | 09:46 AM
heefro757's Avatar
Default camber kits?
the 99 gsr i bought has already been lowered with unknown adjustable shocks. i looked at the tread on the tires and noticed the insides of them are completely worn leaving the outsides in good shape. what is an affordable and reliable way to fix this so i wont ruin my new tires too fast. this wont be a race car just a every day driver. any help will be appreciated.
Old Aug 19, 2007 | 10:05 AM
4drman's Avatar
Default Re: camber kits? (heefro757)
camber kits would be a good idea for that. but it wouldn't solve ur problems but it will help.
Old Aug 19, 2007 | 10:25 AM
littlejj26's Avatar
i agree. camber kit would help fairly well, and it would be even better if you got an alignment after it was installed
Old Aug 19, 2007 | 11:43 AM
heefro757's Avatar
Default Re: (littlejj26)
any suggestion on what type? i have seen these cheaper kits with just some bolts and bushings and others with the actual control arms. i wanna do it right but not over spend.
Old Aug 19, 2007 | 12:33 PM
SleeperGSR's Avatar
Default Re: (heefro757)
get an alignment. See how far out of spec you are, you may not even need a camber kit if you can get close enough to spec. Your toe adjustment is most likely causing your wear.
Old Aug 19, 2007 | 12:37 PM
SlammedBlackGSR's Avatar
get a skunk2 camber kit...........just purchased one and saved me from buying tires every month!!
fin781
Dec 27, 2011 04:18 AM
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
91EF919
Jun 30, 2009 04:11 PM
vteg
May 10, 2002 07:04 PM
