camber kit needed for the eibach pro kit?
Old Mar 17, 2003 | 01:16 PM
Jolf's Avatar
Default camber kit needed for the eibach pro kit?
Have a camber kit on the front with my sagging Neuspeed sports but am going to be changing those out for an eibach pro kit. Question is, will I still need the camber kit on or can I get rid of it? If it is close I'd rather not have to deal with the kit when trying to get the car aligned.
Old Mar 17, 2003 | 01:31 PM
'94gsR's Avatar
New User
Default Re: camber kit needed for the eibach pro kit? (Jolf)
umm....im not sure if the pro kit or the sportlines is the bigger drop, i have the kit that is the lesser of the two in terms of inches dropped and have 17" wheels with no probem whatsoever caber wise
Old Mar 17, 2003 | 02:20 PM
white_rice83's Avatar
Take the camber kit out and then go in for a routine alignment. Ask the mechanic if you're somewhat within stock specifications.
Old Mar 17, 2003 | 02:21 PM
Jolf's Avatar
Default Re: camber kit needed for the eibach pro kit? (white_rice83)
Nods, the pro kit is only a 1.3" drop where as my Neuspeed setup was a 1.75" drop. Now the hard part is finding the stock parts to put back in, think I have em, but if not, classifieds section here I come.
Old Mar 17, 2003 | 02:36 PM
neo1z's Avatar
You def should not need one.
Old Mar 17, 2003 | 04:50 PM
typeR#0427's Avatar
Default Re: camber kit needed for the eibach pro kit? (neo1z)
I have the pro-kit as well. I just took the car in for an alignment and everything was fine. Mechanic said it was not needed(camber-kit)
Old Mar 17, 2003 | 05:11 PM
xteg95's Avatar
Default Re: camber kit needed for the eibach pro kit? (hamB18C1)
, should be fine w/o it.
Old Mar 17, 2003 | 05:28 PM
Jolf's Avatar
Default Re: camber kit needed for the eibach pro kit? (xintegra01)
Argh, don't have the stock pieces any more. Anyone have the stock pieces that a camber kit replaces?
Old Mar 17, 2003 | 05:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have almost a 2" drop, no camber kit and no problems.
Old Mar 17, 2003 | 07:10 PM
Honda Hick's Avatar
If i were you I'd just keep it. My bro's car has a pro-kit and without the kit his car had more than the factory spec negative camber. It wasn't insane but it was out of the range. He got a camber kit and got it aligned and its within spec now. No worries of tire wear. I'd just keep the camber kit, there's nothing wrong with having your alignment within spec.
Old Mar 17, 2003 | 08:13 PM
Community Builder
Default Re: camber kit needed for the eibach pro kit? (Honda Hick)
Yes but adding some more negative camber than factory spec will greatly aid the car's handling. If you keep the toe set to EXACT factory specs you won't have any tire wear problems. On my old tires I went 25K miles with -2.3 deg. camber before I replaced them. It's all about the toe setting.
BaLLeRX
Honda Civic (2006 - 2015)
Sep 17, 2007 02:21 PM
hondamanforlife
14
Apr 4, 2007 07:33 PM
IloveNewt
May 5, 2003 10:24 AM
