camber kit?
Old Jan 16, 2007 | 10:11 PM
wardseg6's Avatar
Default camber kit?
Ok so whats the best bang for your buck camber kit for my integra 97?! Im freakin tired of replacing the tires!
Old Jan 16, 2007 | 10:12 PM
numbnuts22715's Avatar
I wouldnt cheap out on one if I were you..
and I would recommend the upper control arm style, I think theyre called that anyway... but theyre the type that omnipower and skunk2 make.
akandok's Avatar
Default Re: camber kit? (wardseg6)
i used to have the Skunk2. depending on your suspension setup and the type of roads in your are these are nice. our roads are pretty good so they worked for me.. ebay theyre like 170..you could get used around 40
Old Jan 16, 2007 | 10:29 PM
E.J.'s Avatar
わたしは。。。
Have had no problems with tire wear without camber kits. I would just make sure you get it aligned after the drop and tell them to fix the toe. Been running on the same tires [205/45 Nittos] and they have very minimal wear from not having a camber kit.
Old Jan 16, 2007 | 10:36 PM
hooddub's Avatar
k-mac.com pt# 331116G Camber,Caster and toe adjustable.
Old Jan 16, 2007 | 11:40 PM
SlammedDC2teg's Avatar
Default Re: (hooddub)
go with skunk2, omni or block full upper controll arms with ball joint camber adjustment. Im tucking tire with around -1.5 camber in the front with no problems.
Old Jan 17, 2007 | 12:56 PM
wardseg6's Avatar
The car is lowered 1.5 front and rear.
Old Jan 17, 2007 | 02:36 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wardseg6 &raquo;</TD></TR><TR><TD CLASS="quote">The car is lowered 1.5 front and rear. </TD></TR></TABLE>
1.5" is nothing, and requires no camber correction for good tire wear. Besides, any replacement UCA with camber adjustment will reduce what little front suspension travel we already have, due to the taller balljoint.
Fo-Do Fanatic
20
Feb 10, 2011 01:34 PM
CoastalSi
17
Dec 30, 2009 06:38 PM
KDvtec5757
Nov 20, 2008 08:24 PM
tvman
Feb 8, 2006 02:29 PM
9KRacer
10
Feb 1, 2003 11:38 AM
