Camber
Old Mar 19, 2003 | 09:38 PM
xstalkrx's Avatar
Default Camber
When dropping a car....lets just say a 95 GSR, do you have to buy a camber kit? If you dont get a camber kit you end up buying new tires all the time right?
Old Mar 19, 2003 | 09:39 PM
x James Bond x's Avatar
Default Re: Camber (xstalkrx)
do a search, there is a BUCKET O INFO on this subject
To answer quickly you may or may not need a camber kit. It depends on how low you go and how long you want your tires to last.
good Luck
Old Mar 19, 2003 | 09:48 PM
UnionCity LS's Avatar
you dont have to do anything...you dont wanna do you could buy tires every other month if it made you happy...and you can make all us happy by searchin
Old Mar 20, 2003 | 01:12 AM
tC_Dragon's Avatar
Default Re: Camber (EneMy X)
ok, depends how much drop you get. Once you put some lowerin springs on ur car, you will want to wait until the springs settle before you do anything. If you have a sever drop like 2" or more, than my personal opinion is that u should get a camber kit. A few members here have gone by without gettin a camber kit, but i guess its up to you. If you do get a camber kit, then install it, then take ur car in to get it aligned. The front camber will be worse off than ur rear. For suggestions on a camber kit, i recommend the skunk2 kit as many others do.. and if u have further questions in regards to that kit... IM me i will give you some more info then.
CalgaryAccord
Aug 2, 2005 05:21 PM
eymnewdc4
Jul 17, 2005 12:36 PM
civicracer12381
Apr 25, 2004 05:35 PM
DC4 teg
Dec 17, 2003 04:17 PM
