camber?
Old Jun 26, 2006 | 09:33 AM
-Championship-'s Avatar
Default camber?
my rear diver side tire has always need a camber....and it wasnt even dropped when i got it, its dropped now about 1 1/2 inch, so it butterflies even worst, so my question is, if i install a camber will it go all the way in?...or will it just go as far as when i got it?..
Old Jun 26, 2006 | 10:33 AM
Default Re: camber? (project_B18C1)
anybody?
Old Jun 26, 2006 | 01:39 PM
c'mon now anyone?
Old Jun 26, 2006 | 01:52 PM
goddammit...i really need help on this one
Old Jun 26, 2006 | 01:59 PM
Maireeka's Avatar
Your query is kinda vague. Are you saying that your car was cambering when you got it, then you dropped it and it's cambering more? Now you want to know if you can get a camber kit to zero it out like its supposed to be?
If you install a camber kit and get an alignment afterwards then you should be zeroed out like it's supposed to be, not slightly cambering like the car was when you bought it.
DISCLAIMER: I prolly didn't use the right terms, but I'm pretty sure the substance of my post is correct.
Old Jun 26, 2006 | 02:12 PM
rdssk8rcs1's Avatar
Default Re: camber? (Maireeka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maireeka &raquo;</TD></TR><TR><TD CLASS="quote">Your query is kinda vague. Are you saying that your car was cambering when you got it, then you dropped it and it's cambering more? Now you want to know if you can get a camber kit to zero it out like its supposed to be?
DISCLAIMER: I prolly didn't use the right terms, but I'm pretty sure the substance of my post is correct.</TD></TR></TABLE>
he got the idea across
every camber kit ive seen is fullly adjustable and replaces stock parts so it could set a completly different align from stock easily
Old Jun 26, 2006 | 04:27 PM
Default Re: camber? (rdssk8rcs1)
yeah thanx, i was kinda worried that it wouldnt go to zero, i heard that acura rear camber is -2 is that right?..even so, my car was way off when i bought it, how strange, it wasnt even dropped and the rear driver side tire is looking a little towards the left . also, not only is it butterflying but its going to the left, they can fix that right?
Old Jun 26, 2006 | 04:33 PM
not a very clean picture, its from my phone...but you can see that it needs a camber and its facing towards the lefta little....this is the only tire that is doing this.
&lt;center&gt;
&lt;/center&gt;
Old Jun 26, 2006 | 05:53 PM
CleanLikeJdm's Avatar
Hype-R Stalker
^That seems more of something is damaged.
Old Jun 26, 2006 | 05:57 PM
H.'s Avatar
H.
Default Re: camber? (FlatBlackTeg)
washers for the win
Old Jun 26, 2006 | 06:54 PM
Default Re: camber? (JDMDC4..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC4.. &raquo;</TD></TR><TR><TD CLASS="quote">washers for the win </TD></TR></TABLE>
id rather do it the right way....
and it was hit there before, but i just want to know if its fixable
Old Jun 26, 2006 | 08:05 PM
gsr dood's Avatar
washers are the right way. i think its safer to use washers as a spacer rathher than shitty flimsy adjustable aftermarket rods....
Old Jun 26, 2006 | 10:45 PM
OreoDC4's Avatar
dude on my integra that i recently bought the camber is worse than yours, mine is like 4 degrees off in the front and 3 degrees in the back. im getting camber kits which are costing me about 400 for front and back. your lucky yours is only in the rear.
Old Jun 27, 2006 | 12:35 AM
DC2 Mang's Avatar
Default Re: camber? (Oreo-DC5)
washers and longer bolts will fit this
omni power sells a kit for cheap, id look into that
Old Jun 27, 2006 | 06:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">id rather do it the right way....
and it was hit there before, but i just want to know if its fixable</TD></TR></TABLE>
If you want to do it the right way, then you need to fix the damaged parts, not just throw some washers on there in hopes of a "band-aid" fix.
I can't fathom why someone would repair a wrecked car but leave damaged suspension components on there.
There is the possibility that if the upper camber arm on the rear suspension is the *only* thing damaged, then you could replace those with adjustable upper links and kill two birds with one stone: fix the suspension and gain camber adjustability in the back.
However in most cases a camber kit is not needed. I would just fix it with OEM parts.
Old Jun 29, 2006 | 10:38 PM
tyco's Avatar
Default Re: camber? (PatrickGSR94)
I say do what he said replace the damage parts first, I had the same problem, bent trailing arm, replaced it got 0 for the win
Old Jun 29, 2006 | 11:02 PM
Default Re: camber? (tyco)
nothing is damaged..like i said the car was hit there before...they replaced everything...the frame might me bent just a tad...
Old Jun 29, 2006 | 11:28 PM
tyco's Avatar
hehe i see go with bolts and washers by omni!
Old Jun 30, 2006 | 09:04 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">nothing is damaged..like i said the car was hit there before...they replaced everything...the frame might me bent just a tad...</TD></TR></TABLE>
a tad is a tad too much. If you had negative rear camber on stock suspension (providing you tried to get it aligned) then something is definitely damaged and that needs to be fixed/replaced.
Old Jun 30, 2006 | 09:54 AM
Default Re: camber? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">
a tad is a tad too much. If you had negative rear camber on stock suspension (providing you tried to get it aligned) then something is definitely damaged and that needs to be fixed/replaced.</TD></TR></TABLE>
i havent got it aligned when it was stock...i just want to know if i put the camber will it go to -2...i believe thats the stock negative camber on acuras no?
Old Jun 30, 2006 | 10:20 AM
Erik95LS's Avatar
No thats alot more negative camber than stock. Theres no way to know what a camber kit will do on your car if you have bent suspension components. You can either replace whats messed up or give it a try and hope for the best.
Old Jun 30, 2006 | 01:08 PM
dcdcdc's Avatar
You should go get it checked/fixed anyway. Its been hit there and thats the only place that was cambering when you got so it would just make sense that something is damaged there.
Old Jun 30, 2006 | 02:31 PM
Default Re: camber? (dcdcdc)
so is -2 the stock negataive on the rear?
Old Jun 30, 2006 | 04:30 PM
Yambor's Avatar
nope..
Old Jun 30, 2006 | 04:51 PM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">so is -2 the stock negataive on the rear?</TD></TR></TABLE>
like I said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">No thats alot more negative camber than stock. </TD></TR></TABLE>
