Cam gear problem
Hey folk.
i have a question about the cam gear.
if i rotate the cam gear without the timing belt on. that will cause something problem?
If i did rotate the cam gear without the timing belt on, for many time, how can i fix it back?
Need some advise
because my car is only crank not start. I am thinking because of the cam gear problem.
I know it is stupid, but i need some advise for it. please
Need some advise
if you rotate it without the belt its not a big deal. when you put it back togetehr make sure the arrows are pointing to each other. they wont point together unless you have the belt on though. with the belt off the arrows will be a little bit off.
its been a while. hope this helps
Why you keep asking the same question, I posted the pic on the other thread with the info showing where the cam gears are marked... Do us all a favor and just post some pics it will be a lot more helpful.
DumpdEJ6
Sep 12, 2010 08:05 AM
DMCCOY
12
Jan 9, 2009 08:39 PM
