calling all DA OWNERS!!!! speed sensor problem
Old Dec 12, 2007 | 08:28 PM
Lokisdope's Avatar
Default calling all DA OWNERS!!!! speed sensor problem
i let some IDIOT, or what i call a friend which now has new friends replace my cluster with a current milage cluster thats accurate with my new motor. turns out that your supposed to pull out the clip with the speed sensor thingy on it. he just yanked out the cluster and i was wondering why my speed was not working.
now, i tried to put it all back...but its so hard...such tight space. i tried like putting on the clip with the wire first, then connecting it..but now it just comes off the wire with ease.
what to do?
Old Dec 12, 2007 | 09:31 PM
Lokisdope's Avatar
bump
Old Dec 12, 2007 | 09:56 PM
HONDRETTI's Avatar
Default Re: (Lokisdope)
i just did this same project today, and i thought it was really easy...
just dont break the clip...are you saying you broke the clip?
Old Dec 13, 2007 | 04:37 AM
AWD Terror's Avatar
Default Re: (HONDRETTI)
Get another clip. There's no reason that it should fall off once you have it on correctly
Old Dec 13, 2007 | 06:16 AM
God-Driven's Avatar
if you broke the clip replace it like the others guys told you, the easiest way to do this is removing the clip that holds the cable on the tranny on the speed sensor that way you can pull the cable inside the car to give you enough room to attached the cable correctly.
Old Dec 15, 2007 | 09:26 AM
Lokisdope's Avatar
i didnt break the clip..the clip is apart from the cable thats the part thats hard
Old Dec 15, 2007 | 09:37 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: calling all DA OWNERS!!!! speed sensor problem (Lokisdope)
Changing the mileage on the cluster is illegal. Have you considered replacing the entire cable?
http://www.sonsacuraparts.com/...dIrno=
Old Dec 15, 2007 | 03:06 PM
Lokisdope's Avatar
someones gotta be havin the same problem as me. bump, alternative rather then buying a new cable
Old Jul 5, 2019 | 04:15 PM
blahh brian's Avatar
I'm having issues location a clip to buy does anyone have a part number or like with what the clip looks like thank you?!
Old Jul 5, 2019 | 05:02 PM
tamboo's Avatar
10 Year Member
here's a pic, you may have to buy the entire cable:
https://www.ebay.com/itm/GENUINE-OEM...wAAOSwR-ZZ1CEm
EGed up from the seat up
34
Sep 16, 2008 06:37 AM
ugly rex
Jan 1, 2007 11:19 PM
k7q
18
Mar 25, 2006 04:44 PM
LAWST
Mar 3, 2005 06:51 PM
slow4dr
Dec 27, 2004 07:19 AM
