cable clutch
Old Aug 13, 2007 | 09:30 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default cable clutch
i have a 90 integra with a ys1 cable tranny. i replaced the tranny and now im trying to connect the cable to the clutch and its not holding tight. clutch keeps falling to the floor. when i try tighten the cable it still does the same thing... can ne one help me out
Modified by hondateg10 at 12:36 PM 8/16/2007
Old Aug 14, 2007 | 05:51 AM
hondateg10's Avatar
bump
Old Aug 14, 2007 | 11:21 AM
projectTeG's Avatar
YS2? theres only a ys1(assuming you have the 92-93 tranny). are you sure your connecting it right? you might want to check and see if the cable is connected to the pedal, they sometimes pop off when the cable is disconected and moved around.
BTW is the throw-out bearing in correctly?
Old Aug 14, 2007 | 12:00 PM
LoseRPunKx182's Avatar
Default Re: (projectTeG)
if the cable's installed right than make sure u have the clip that holds the TOB installed correctly too.
cb07
Nov 23, 2009 05:44 PM
turbo-crx
Oct 7, 2008 02:45 PM
b16_swap
Jul 23, 2008 10:07 AM
Sirex
Sep 26, 2003 07:55 AM
