a/c not working
Old Jun 10, 2008 | 03:51 PM
19integra91's Avatar
Default a/c not working
so heres the issue...my 97 teg has a/c...but the compressor clutch is not engaging so obviously its blowing out hot air. check the connector for the compressor clutch and it is not getting any power but i cant find a relay or switch or anything that would...anyone know what controls the power to the compressor clutch and where it is?
Old Jun 10, 2008 | 08:45 PM
94jdmdb8's Avatar
Default Re: a/c not working (19integra91)
the compressor is not kicking on because you have low pressure in the system. the ac pressure switch cuts the circuit off when its too low to protect the compressor.
Old Jun 10, 2008 | 09:40 PM
dohcFTW's Avatar
eh i'm getting the same problem, in for more mines more of a wiring issue though
Old Jun 11, 2008 | 06:07 AM
all-mtr-teg's Avatar
Get yourself a 20 Haynes manual from autozone, it has a detailed section on a/c diagnosis with photos of where the low pressure switch and relays are located.
You should jump the lower pressure switch first to see if the a/c clutch engages. If its does, then it sounds like your freon and low and you will need to charge the a/c system with more freon.
Old Jun 11, 2008 | 02:40 PM
Default Re: a/c not working (all-mtr-teg)
ok cool thanks alot guys im gonna check pressure, i woulda figured the clutch woulda atleast engaged even with low pressure...but im not too too experienced with a/c systems i failed that ase haha...no bueno
Old Jun 12, 2008 | 10:37 AM
rgaray's Avatar
Default Re: a/c not working (94jdmdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94jdmdb8 &raquo;</TD></TR><TR><TD CLASS="quote">the compressor is not kicking on because you have low pressure in the system. the ac pressure switch cuts the circuit off when its too low to protect the compressor. </TD></TR></TABLE>
Question: How are you suppose to recharge it if the compressor doesn't turn on?
Old Jun 12, 2008 | 10:45 AM
Default Re: a/c not working (rgaray)
Jump the lower pressure switch socket.
Old Jun 12, 2008 | 11:35 AM
==Catfish=='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Jump the lower pressure switch socket.</TD></TR></TABLE>
Yes, if it is just that the pressure is too low in the system you could jumper it and it will engage. Then you'll know to just add some R134A on the LOW side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcFTW &raquo;</TD></TR><TR><TD CLASS="quote">eh i'm getting the same problem, in for more mines more of a wiring issue though</TD></TR></TABLE>
No, I think your wiring issue is gone. I got that all fixed for you. I think you're having the same weird problem this guy is having. I even checked your diode for you and that was good.
Old Jun 12, 2008 | 11:49 AM
Also, make sure the condensor fan fuse is not blown. That will also prevent the a/c clutch from engaging.
Old Jun 12, 2008 | 01:57 PM
Default Re: (all-mtr-teg)
checked the fan fuse...good...im gonna try to get to my buddies tonight to run the manifold gauges...ill keep u posted
Old Jun 12, 2008 | 04:38 PM
Jo3f1sh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Also, make sure the condensor fan fuse is not blown. That will also prevent the a/c clutch from engaging.</TD></TR></TABLE>
That was my problem right there. Turned out to be a melted wire hitting the exhaust manifold causing the + and - wires to touch therefore blowing the fuse. Scratched my head on that one for a bit...
Old Jun 12, 2008 | 06:02 PM
Default Re: (Jo3f1sh)
Installed an aftermarket radiator and the mounts for the condensor fan weren't perfect so it tweaked the condensor fan blades and made the motor strain, causing a blown fuse. The blown condensor fan fuse cause the a/c clutch not to engage. I though the condensor fan wasn't coming on cause the a/c clutch was getting power. It took me a few days to figure out the problem
CG01
Engine Management and Tuning
Nov 7, 2012 08:18 PM
whahappened
Acura TSX
Nov 2, 2012 03:20 PM
sonnyny
Honda CR-V & Element
Jun 10, 2012 10:07 AM
sk8er602
May 22, 2007 07:25 PM
jdadams12
Jul 13, 2006 08:05 AM
