A/C...Climate control electrical problem!
The light for the climate control on my integra is whacked...In order to get it to turn on, I would have to hit it on the side for it to light on..and sometime it wouldn't turn on at all..Any ideas on how to fix the problem guy?
why is this a poll/you can add poll choices?
anyway mine did that too... I was told to change the light bulbs but before I got around to doing that I got rear ended...
on my car.. if I cornered/turned really hard.. it would light back up.. but a safer approach to getting it to light was to turn the temp slider from cold to hot back to cold (cuz I liked to keep it on cold)... it would light up after that... I felt bad smacking my car when I wanted the CC to light up heh...
o man i had this problem. none of the lights on my climate control would light up. what you have to do is rip out the climate control. pop out the hazard and defrost buttons with a screw driver. be careful. they should just pop right out. unplug the plugs and you will find two screws take them out. now you have to go under the dash and find the heater wire. i'm not sure how to explain it but check the link. then pop the **** out unplug the plugs and change your little blubs. you have to get them from acura since they are so small.
http://www.team-integra.net/sections...?ArticleID=586
good luck
[Modified by sheehan024, 5:23 PM 3/23/2003]
good luck
But I still don't get why sometime it comes on and sometime it doesn't.. Anyway, how much would the bulb cost at the dealership for each?
luiscostahonda
Jul 30, 2017 06:41 PM
Midori Green
Oct 27, 2008 07:24 PM
