bsq or beaks??
Old Mar 31, 2003 | 09:11 PM
TurboBumblBee's Avatar
Default bsq or beaks??
im installing an ITR rear sway bar onto my civic coupe and wanted to get opinions on both reinforcement kits.. so how do they compare? beaks looks like its stronger but its expensive comparted to the bsq kit..
Old Mar 31, 2003 | 09:16 PM
95 Gizzer
Guest
Posts: n/a
Default Re: bsq or beaks?? (Hybrid95CivicEX)
I think Beaks requires some other modification that BSQ doesnt make you do. Go with BSQ
Old Mar 31, 2003 | 10:03 PM
tC_Dragon's Avatar
Default Re: bsq or beaks?? (95 Gizzer)
i agree wit you on the assumption that the beaks looks sturdier, but it is also more of a pita to install. The bsq kit is pretty straight forward and i'm not sure about the civic application of the itr bar... but i have yet to hear a single complaint about teh bsq kit on integras. jus my 2cents.
Old Mar 31, 2003 | 10:08 PM
xteg95's Avatar
Default Re: bsq or beaks?? (pdcdragon)
https://honda-tech.com/zerothread?id=458999
Search is your friend Otherwise unless you're going to be doing autox or anything more suspension related i'd say just save your money and get the bsq kit.
Old Mar 31, 2003 | 10:10 PM
i think im going to order the bsq kit cause it does look easier to install and a lot cheaper.. im going to also order the parts that are listed on the bsq site and look for a set of used integra lca.. so its only gonna be about 130 for the itr sway bar and then a used set of lca about 70 bux.. not bad for a nice sway bar setup
what tie bar does everyone use w/ the bsq/itr combo????
slateEKsi
Jun 7, 2015 10:20 AM
Ruben19
Suspension & Brakes
May 7, 2010 11:02 AM
-Championship-
Jan 8, 2007 09:59 AM
Sassafrass
Nov 26, 2003 06:43 PM
TurboBumblBee
Apr 1, 2003 07:46 AM
