brake question
ok, i have searched and have not found the answer i was looking for. well my question is, if i was to purchase a integra type r MS and brake booster, would it work if i was to get non-abs prop valve and brakes lines? well, im trying to remove my abs on my 95ls. and the type r MS and brake booster that im planing on getting looks similar to the RS MS and brake booster.
thanks
thanks
yeah it does. but i heard that the 98+ integra all has the same brake booster and MS(gsr, ls, rs, gs, ect). but im not sure if the type Rs are the same. because i already have a prop valve from a 99rs. and i thought i read it on a thread that if you had a 98+ integra w/ abs and want to remove it, all you would need is RS brake lines. correct me if im wrong
743power
Apr 23, 2003 03:19 PM
