Brake lights stuck on
OK I drive a 95 LS and I'm at work right now and a security guard just came in and told me my brake lights were on. I went out to check and they are stuck on. I think maybe what might have caused it is the fact that I use that club device that goes underneath the brake pedal and locks onto the steering wheel to keep the pedal from being pushed in. I pressed the brake in and out and its still stuck on. I had to pull the fuse for it to turn off. I work the night shift so I won't be able to do anything with it till 7am but does anyone know what I should check for? Is there anything around the brake pedal that might be stuck? Any help would be greatly appreciated. Thanks in advance .
LOL, the plastic piece broke out of the hole that pushes in the switch to turn off the light on the pedal bar. I work at the hospital so I took an insulin syringe and pulled the push part out that has the mushroomed head and put it in the hole and taped off the end. Thanks for the advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 »</TD></TR><TR><TD CLASS="quote">they just let you take syringes? thats kinda shady.</TD></TR></TABLE>
They should but even if its a syringe it should be without the needle like the hospitals ehre
This just happened to my car as well. I haven't gotten around to looking up under the dashboard, but I found little pieces of plastic all about. After time, I guess the plastic got brittle and cracked. Has anyone here replaced this part and have a part # for it?
From: Why so you can pretend like youre interested, FL/OK
Is the plastic piece right under the rubber part of the brake pedal or is it high up on the arm, closer to the firewall. The Helms never really mentions this, I just got lucky I remembered a friend mentioning something the plastic pieces some time ago.
You can use just about anything to plug the hole in the arm where the switch engages. I used a plastic body fastener, you can use a nut and bolt, and I have even heard of someone glueing a dime to the arm.
I just had this same problem happen to my 1991 Honda Accord. I found the remains of the stopper on the floor board and my brakelights wouldn't go off. I disconnected my battery and searched the internet for answers. Luckily I found this forum! I've temporarily taped a dime over the hole where the stopper was and the brake lights are now working fine. Pep Boys didn't have the part but the Honda dealership should have it in a few days....the cost is less than 3 bucks.
asocallocal
Aug 29, 2010 07:00 PM
musclehead954
Feb 27, 2008 10:28 AM
