Brake Light problem...
Old Aug 16, 2007 | 02:30 PM
btman's Avatar
Default Brake Light problem...
For some reason my brake light will stay on after the e-brake is down. This used to only happen when it was very cold outside but it is doing it now as well. Eventually after driving a little bit the brake light will go off when i come to a stop. I have no idea what it is and I checked my fluids and have new pads on. Can anyone help?
Modified by btman at 4:07 PM 8/16/2007
Old Aug 23, 2007 | 02:11 PM
TrueUntilDeath.com's Avatar
Default Re: Brake Light problem... (btman)
I had the same problem. I think its the sensor in the resoviour being sticky. I did a full brake flush and it solved the problem.
Old Aug 23, 2007 | 02:52 PM
Da9Gro's Avatar
check to see if your brake fluid is low first, before you do anything, cuz that can cause the brake light to turn on, well on obd2 i know for sure
Old Oct 12, 2007 | 06:11 AM
btman's Avatar
Default Re: Brake Light problem... (Da9Gro)
im going to go ahead and do the flush...ill let you know how it goes...thanks for the input.
intech
Nov 17, 2005 02:44 PM
HardSaltydogg
11
Jun 18, 2005 04:11 PM
civicboisi
Mar 8, 2003 06:45 AM
ace1875
12
Jan 17, 2003 06:55 PM
hybridbmw
Feb 19, 2002 10:38 AM
