brake light in the dash is on
Old Aug 21, 2003 | 08:45 PM
216.226.142.95:27016's Avatar
Default brake light in the dash is on
the parking break light on my dash is lit for some reason. i noticed that it happend when i took off my spoiler. what can i do to fix this problem?
Old Aug 21, 2003 | 08:48 PM
King_j's Avatar
Default Re: brake light in the dash is on (216.226.142.95:27016)
parking break = e-brake? if so, then your spoiler light should have nothing to do with the dash light, one light is a e brake light and the one you removed would be considered a brake light. by the e-brake assembly there is a swith which controls this light, forgot what its called, but you might wasnt to check it out.
Old Aug 21, 2003 | 08:51 PM
Default Re: brake light in the dash is on (King_j)
the thing is, it only happen sometimes. it usually happens when i just star my car in the morning and it goes away after a few minutes, but today it rained and it was on the whole time.
Old Aug 21, 2003 | 09:49 PM
LoudLude's Avatar
1. check your brake fluid (seriously.)
2. find the wires that ran to the spoiler brake light, connect them, and tape them.
3. report back.
Old Aug 21, 2003 | 10:38 PM
WOTTEG's Avatar
Default Re: brake light in the dash is on (LoudLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoudLude &raquo;</TD></TR><TR><TD CLASS="quote">1. check your brake fluid (seriously.)
3. report back.
Perfect Advice!
Brake Fluid resevuior should be "topped off (as in ABOVE the MAX line).
Old Aug 21, 2003 | 10:53 PM
Bob_Digi's Avatar
check ur brake fluid
Old Aug 21, 2003 | 11:06 PM
thaiphob's Avatar
Nikon!!!
Default Re: (bob evans)
yep its the fluid.
Old Aug 22, 2003 | 07:39 AM
Bill Hook's Avatar
I'd like to know when the last time you had your fluid flushed was?
Topping off may be a temporary fix, but if the fluid is so low, then it sounds like more maintenance is required.
Old Aug 23, 2003 | 08:12 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: brake light in the dash is on (Bill Hook)
Same thing is happening in my car. I will check the brake fluid tonight!
Old Aug 23, 2003 | 01:51 PM
1Tym's Avatar
Default Re: brake light in the dash is on (arizsun21)
do your guys' car sometimes jerk when u brake? for me it seems to happen when i am braking hard or going fast (not soo fast fast though) downhill, but the other day it happened on leveled ground. My car has been doing this once in awhile for a long time. Recently, the brake light on the dash has been staying on or going off & on for like a week. I finally took it to the dealer today (how convenient that the light didnt appear anymore since yesterday) and they said nothing was wrong with it and that the brake fluid was good.
Old Aug 24, 2003 | 03:36 AM
WOTTEG's Avatar
Default Re: brake light in the dash is on (1Tym)
How's the condition of your brake pads 1Tym?
Have you checked that the parking brake switch in your center console is moving freely?
Old Aug 24, 2003 | 12:53 PM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Tym &raquo;</TD></TR><TR><TD CLASS="quote">do your guys' car sometimes jerk when u brake? for me it seems to happen when i am braking hard or going fast (not soo fast fast though) downhill, but the other day it happened on leveled ground. My car has been doing this once in awhile for a long time. Recently, the brake light on the dash has been staying on or going off & on for like a week. I finally took it to the dealer today (how convenient that the light didnt appear anymore since yesterday) and they said nothing was wrong with it and that the brake fluid was good. </TD></TR></TABLE>
All those symptoms still sound like you need more fluid. The sensor seems sensitive to being even slightly low and going downhill and braking from speed can cause the fluid to leave the sensor "dry." I had this happen and put about an ounce in to make it go away. It happened right after I got by system flushed.
Old Aug 24, 2003 | 01:13 PM
babes 99 GSR's Avatar
Hey, i have this problem and have posted about it before. My fluid is topped off and my pads are fine...
I did notice my spoiler brake light is out though.
What came of this problem?
Old Aug 24, 2003 | 01:16 PM
b18C1_liLkyLe's Avatar
i've had the exact same problem for a couple monthes and likewise its and 'on and off' thing. someone told me that the e-brake sensor might need 'adjustment' but i dont know how to go about doing that. the break fluid tip is new to me so i'll check that out.
Old Aug 24, 2003 | 11:21 PM
BlueIntegraBoy's Avatar
This has recently happened to me about 2 weeks ago. I would start the car up in the morning and the light would be on. Then one night, everytime I accelerated it went on, and went off after I braked. I found out it was my fluid in the resevoir. I checked the fluid level a week before the light went on and it was about 1½ inches above the MIN line. I added fluid until a little bit over MAX and there has been no light since. I guess that sensor is sensitive.
PatrickGSR94
Oct 7, 2015 01:55 PM
outlawstar27
May 18, 2007 09:04 AM
ryanjusmc
Oct 1, 2006 11:31 AM
Jeff99Base
Sep 6, 2003 07:09 AM
