brake broblems PLEASE HELP
Old Aug 18, 2006 | 12:07 PM
gsr1289's Avatar
Default brake problems PLEASE HELP
i just installed a new right rear caliper and new pads on both sides the pads are organic compounds i want to nkow if its normal that im smelling a burning odor while they are breaking in. and the odor smells like if u leave water in a pot to long while on the oven and it burns out. ewww. so if any one knows ne thing bout this please respond.
thanks
Modified by gsr1289 at 1:44 PM 8/18/2006
Old Aug 18, 2006 | 12:17 PM
gogogomoveit's Avatar
Default Re: brake broblems PLEASE HELP (gsr1289)
when u say break in...how do you break it in? SOme pad manufacturers recommend you to brake aggressively, and it will be normal to smell pads.
http://www.stoptech.com for more details.
If you continue to smell odor a while after you have taken off the brakes, something is not right.
Old Aug 18, 2006 | 12:26 PM
gsr1289's Avatar
Default Re: brake broblems PLEASE HELP (gogogomoveit)
by break in i just mean like the first few inital days of breaking. but if this helps the caliper was sticking and so i replaced it today and put in new pads. but with the old pads and old caliper it wasnt making that smell. so could something be wrong with the new caliper or is it just the bads or could even possibly that something was on the pads like maybe a tiny bit of brake fluid got on the pads? any more advice would be GREATLY apricitated
Old Aug 18, 2006 | 12:51 PM
any stain on the brake disc will be rubbed off right away. So its not fluid on the disc. The thing you are smelling should be brake pad. Does the smell persists? If it does, try jacking that corner off the ground and spin the wheel by hand. See if it is rubbing or not. If no, then probably things are alright
Old Aug 18, 2006 | 12:55 PM
gsr1289's Avatar
well i just put the pads on today and i asked a couple guys if that was normal and they said it was but if it doesnt go away after a few days to get it checked out. got any ideas on what i could be if it is rubbing with tire of the ground?
Old Aug 18, 2006 | 01:02 PM
maybe the pads are not inserted right so it doesnt align parallel, and keeps rubbing the disc...or the disc itself is shot. If the disc is unbalanced you can feel it thru the brake pedal. Just try if the wheel can spin freely
Try drving for a day or 2 to see if that persist. The smell is probably just the bonding resin of the pad material burning in the first usage. Perfectly normal.
Old Aug 18, 2006 | 01:05 PM
gsr1289's Avatar
awesome thanks alot for the help i really apreictate it, alot of the times when i do post i only get a few respones that arent very helpful.
mickey513
Nov 16, 2018 03:56 PM
PatrickGSR94
Suspension & Brakes
11
Oct 4, 2007 08:11 AM
kornerk12
Aug 7, 2006 06:33 PM
94gsr_vtc
Mar 30, 2005 06:34 PM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
