Bought a b18c1
Old Aug 7, 2014 | 01:27 AM
tagar89's Avatar
Default Bought a b18c1
Well i bought a db8 shell with a db6 front end. I wasnt going to buy the engine but here i am posting. Its a boosted c1. Sure it sounds cool at first but then i learn more about it. Its a C1 with b16 pistons which would jack up the compression. I speak to the engine builder and he said he built it as a high compression engine. Didnt build it for boost. Well here is what i found. Compression on #2-4 210, #1 120. Leak down test revealed either a burnt piston or the rings are fried.
"now me and the mad scientist have to rip apart the block and replace the piston rings your fried"
Sorry couldnt help myself
Here are the "build specs"
b18c1
micro polished crank balanced and matched to rod lenths all new bearings (kings)
new oem gsr rods
new b16 pistons and new rings
block was line bored decked and honed
new head gasket
GSR head
ARP head studs
new dual valve springs
new titanium retainers
new valve seals
new cam seals
skunk2 adj cam gears
skunk2 throttle body i believe 72mm
skunk2 manifold
450cc injectors with resistor box
walboro 255 fuel pump
GSR tranny rebuilt all new bearings on it it use to grind 3 at high rpms now shifts perfect flawless
exceedy stage 1 clutch with stage 2 pressure plate
lightened fly wheel and was balanced before installed
both new axles
.58 ebay turbo boosted on 9psi with a street tune on crome (p28 ecu)
3inch down pipe to flex pipe and 2.5 full apexi exhaust car sounds mean and bov is LOUD (hks ssqv limited black edition) all motor work was done by Nate at Daily driven motor sports i can meet up at his shop he can show proof of work probably about 15k on rebuilt
Forgive me for my ignorance, im a chevy guy but as you can tell ill get into other stuff.
So it sounds to me like this motor has to be over 11:1. Sounds like a bad formula to boost. Im obviously rebuilding it. What do you guys think would be the best route. Take the turbo off and build an all motor deal? I love boost just like 95% of people out there. Any tips and advice is appreciated.
Thomas
Old Aug 7, 2014 | 06:45 PM
tagar89's Avatar
Default Re: Bought a b18c1
Nothing?
Old Aug 8, 2014 | 03:22 PM
kaycee_00's Avatar
You'll probably get more input over in the forced induction section then here, https://honda-tech.com/forums/forced-induction-16/. I wouldn't be scared of high compression and boost though. Its better to run lower boost and have the motor do the work then run a low compression and have to run higher pressures to make up for it.
Old Aug 8, 2014 | 04:45 PM
tagar89's Avatar
I'll start it there. It's just the questions has n/a and boost in it so I just put it here . Thanks
Old Aug 8, 2014 | 04:55 PM
kaycee_00's Avatar
No problem. And it depends on what your planning to do with the car. If you plan on just having fun with it, you can't beat boost. My cars been boosted for 4 years (stock b20v) and theres never a dull moment while driving it.
tagar89
Jun 27, 2015 09:34 PM
tagar89
10
Oct 6, 2014 07:24 AM
acura_b18c1
15
Jun 4, 2006 08:31 PM
NightmareApex
Oct 24, 2005 09:36 AM
NightmareApex
Oct 19, 2005 07:35 PM
