boosted ls
Old May 1, 2003 | 02:04 PM
p1ccoloz's Avatar
Default boosted ls
how many lbs of boost can a stock ls motor handle. also how much boost could a ls motor that has aftermarket rods, pistons, and resleeved block handle? how many lbs do most boosted ls run and what are your numbers? a rough estimate is good enough, thanks
Old May 1, 2003 | 02:08 PM
SuzukaBlueAP2's Avatar
Default Re: boosted ls (p1ccoloz)
it'll hold 10 psi stock. but not for long. your stock pistons will be fine for awhile too. They're at a friendly 9.2:1 CR. I'm not 100% sure, and I'm sure everyone's info differs on this, but the stock sleeves and rods as well as the bearings, will probably weakend dramatically at around 300whp. You could probably very easily get away with putting a turbo kit on and leaving everything stock for awhile. But, plan on spending some cash in the future to sturdy up that motor. even a block guard, new bearings and seals will buy you some time. But if it's daily driven, a built inside would be best.
Old May 1, 2003 | 02:09 PM
dohc-nyne's Avatar
with stock internals..7 psi is a safe route...8 psi is max i would push it.....
with built internals...i dunno...12 - 16 i think
88.REX
Sep 27, 2009 12:41 PM
EF9SIRJeff
Aug 29, 2006 06:13 AM
95integraLS003
Sep 13, 2005 05:45 AM
AccordDX89
Mar 2, 2005 05:22 PM
bubblebackinSI
Apr 7, 2004 08:20 AM
