Bogging under acceleration
Hey so I know there was a thread on this but I need answers, so when my car is warm it bogs down I changed the coolant temp sensor and that fixed the problem for a while but since then I didn’t drive for a week then it started doing it, it idles around 790-840 rpms. Thanks.
Try to reset the ECU by unplugging the battery for a few mins.
Check the wiring to the ECT sensor plug, you may have a bad plug with worn out wires, inspect the plug for anything cut pulled or corroded.
But I replaced the plug and it worked fine for 3 months, could it still have anything to do with the wiring?
