Body Control Module?
Old Jul 23, 2014 | 04:28 PM
seth01tuner's Avatar
Default Body Control Module?
Where is the body control module located and what does it look like? I have tried researching and can't find too much about it. My mechanic thinks that the BCM is the culprit to an issue i've been having with my integra. Thanks
Old Jul 23, 2014 | 07:57 PM
B_Swapped93's Avatar
Default Re: Body Control Module?
the ECU? pass side kick panel as there is no body control module.
Old Jul 24, 2014 | 08:12 AM
I didn't think there was, and not the ECU, I have been having speedometer issues and my mechanic called Honda, and they said try the body control module...
Old Jul 24, 2014 | 03:02 PM
VSS it's located on the trans you'll see it back lower protion 3 wire plug. OR it's the cluster again easy fixes
Old Jul 24, 2014 | 06:51 PM
Yeah I already replaced the cluster with another one, switched the speed sensor out with a new one, and check the plug and all wires were fine no corrosion and making good contact. That's why I asked my mechanic and he told me it might be the BCM so im out of ideas.
Old Jul 25, 2014 | 10:03 AM
I checked for continuity in the vss plug and the orange wire is at 9.92, black and yellow is at 12.29, and the black(ground) is at 0.01
SpOoLiNg CiViC
Dec 8, 2009 03:35 PM
HmgLauj69
Jun 8, 2005 10:48 AM
phreaker
Jan 29, 2003 10:38 AM
.ShawnD.
Aug 10, 2002 11:15 AM
