1)I believe my Waterpump is slowly leaking, not sure if it is from the bleed hole or the rubber seal. I would assume it is from the bleed hole?
2)I've read that this is a sign that the grease seal is compromised so instead of the coolant contaminating the bearing it leaks through the hole, is this correct?
3)Are the weep holes designed to keep the coolant from reaching the Timing Belt?... I would hope so.
4)It is a very slow leak, not sure if this is even normal.
Thanks
Thanks
slow leak...it's more than likely coming from the bottom "weep" hole from the water pump.
replace the pump ASAP.
Really, it's been like this for 2yrs, car never overheats. It's an OEM WP, and
It's been changed once
Its perfectly fine and normal, dont worry about it.Originally Posted by MechEng
Really, it's been like this for 2yrs, car never overheats. It's an OEM WP, andIt's been changed once
Quote:
Thats what I figure, I've heard that you can hear the WP going bad anyway?Originally Posted by B20ztek
