battery light
Old Jul 3, 2009 | 04:41 PM
ef1991hf's Avatar
Icon3 battery light
my battery light is still on i just installed a new remand alternator about 400 miles ago, i drive a 1991 acura integra ls i need some trouble shooting here. Any place i should look, the belt was squealing but it was new and on the right track, could i have installed a bolt incorrectly? please help!
Old Jul 3, 2009 | 04:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: battery light
Do you own a volt meter?
Old Jul 3, 2009 | 05:29 PM
ef1991hf's Avatar
no i do not. sadly.
Old Jul 3, 2009 | 05:33 PM
Dogginator's Avatar
Daisy... Daisy...
Go to an auto parts store and have them check your battery and alternator. The will check the voltage with the car off, the car running, and the car running with an electrical load (headlights, blower motor, defroster, etc. on).
Old Jul 3, 2009 | 05:34 PM
ef1991hf's Avatar
so i need to remove the alternator and take it up there or the whole car because i do not know if it will make it there.
Old Jul 3, 2009 | 05:36 PM
Dogginator's Avatar
Daisy... Daisy...
The whole car. Can you borrow a volt meter or buy one for about $20?
Old Jul 3, 2009 | 05:43 PM
ef1991hf's Avatar
maybe, i will try do you know of anything that could affect this though? this will be the 3rd alternator i have put on this car in 20k miles.
Old Jul 3, 2009 | 05:44 PM
Dogginator's Avatar
Daisy... Daisy...
I would check the engine ground as well.
Do you have a large stereo or other power draw?
Old Jul 3, 2009 | 05:55 PM
MoreBoost!'s Avatar
What he said.^^^
Also. Check the harness to the alternator to see if you have any cracks or bad connection.
Old Jul 3, 2009 | 06:06 PM
ef1991hf's Avatar
my car is stripped!!! i have no radio the only thing that drams power is the motor, a a/fr gauge, and accesories like the lights and stuff. where would the engine ground be located i see two grounds, one goes to the tranny, the other goes to the valve cover, and they both look good.
Old Jul 4, 2009 | 08:29 AM
ef1991hf's Avatar
could the ground for the alternator be run to the same ground as the ground for the radiator fan does? if so i think this may be my problem i had to run a new ground for my fan a while back, and ever since then my alternator has squealed. and if this could be i would appreciate any information concerning which wire is the ground.
Old Jul 6, 2009 | 08:22 PM
crazyboy's Avatar
try regrounding it
oneprblmcat
Honda CR-V & Element
Jan 23, 2012 07:05 AM
sixgunsound
Jun 7, 2009 05:45 PM
vietkangta
Oct 21, 2007 09:20 PM
touintegra1
Mar 26, 2006 05:11 PM
StatGSR
Jan 20, 2004 06:02 PM
