Is it bad to vtec if your engine is cold?
Old Feb 15, 2004 | 12:51 PM
JadeDM's Avatar
Default Is it bad to vtec if your engine is cold?
just curious is it bad for the engine if its cold and i vtec it?
Modified by JadeDM at 6:49 PM 2/19/2004
Old Feb 15, 2004 | 12:58 PM
2trix's Avatar
Default Re: Is it bad to vtec if your engine is cold? (JadeDM)
well you always risk the chance of engine damage when going to redline...when your engine is cold its not worse then if your engine is warm...its doesnt matter...
Old Feb 15, 2004 | 12:59 PM
Kendall's Avatar
Putting unnecessary stress on your engine isn't good if it's not up to proper operating temperature. There are many reasons for this. I suggest you search.
markdman's Avatar
yes, its very bad. If its a stock ecu your v-tec shouldnt have enguaged. if your using a v-afc, jut dont rape it when its cold
Old Feb 15, 2004 | 01:00 PM
StatGSR's Avatar
Default Re: Is it bad to vtec if your engine is cold? (2trix)
vtec shouldnt engauge if its cold, but if it was still able to cross-over then i dont think its a big deal. but reving that high w/o VTEC working probably isnt a good idea.
Old Feb 15, 2004 | 02:29 PM
R Legend's Avatar
Default Re: Is it bad to vtec if your engine is cold? (StatGSR)
over all i just wouldn't run the car that hard for at least 5-10 min to make sure the oil is circulating correctly and at correct temps. Friction and metal on metal is never good.
just go easy on her especially if its cold
Old Feb 15, 2004 | 02:31 PM
integraL's Avatar
Default Re: Is it bad to vtec if your engine is cold? (vtecjerry)
yeah you wont hit vtec until the car is at normal running temperature
Old Feb 15, 2004 | 02:53 PM
2trix's Avatar
Default Re: Is it bad to vtec if your engine is cold? (integraL)
exactly! the ecu determines if vtec will kick in or not...therefore when you hit vtec you may think the cars cold...but its probably not...and within the first 5 seconds of your car running the motor has plenty of oil pressure not to damage anything...
Old Feb 15, 2004 | 03:21 PM
thegsrman's Avatar
for vtec to engage you need oil pressure, right coolant temp, rpm, engine load and speed, throttlle position. any one of these not ideal, vtec will not engage.
Old Feb 15, 2004 | 03:22 PM
Boost2NA's Avatar
VTEC works off of oil pressure and water temp. Like said earlier if it crossed over then your car was at operating temps so its all good. Now if it wasnt warmed up and u went to redline with no vtec thats not good. Always wait till its warm to give it hell.
Old Feb 15, 2004 | 03:37 PM
Rory Breaker's Avatar
Default Re: Is it bad to vtec if your engine is cold? (Boosted99Si)
Exactly...water temp has to be up to normal operating temp for VTEC to engage. On a cold motor, no engagey.
To repeat what everyone else is saying...you really shouldnt run your car hard until it is up to normal operating temperature...
Old Feb 15, 2004 | 03:57 PM
B18C2_sedan's Avatar
Default Re: Is it bad to vtec if your engine is cold? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Exactly...water temp has to be up to normal operating temp for VTEC to engage. On a cold motor, no engagey.
To repeat what everyone else is saying...you really shouldnt run your car hard until it is up to normal operating temperature...</TD></TR></TABLE>
good info
Old Feb 15, 2004 | 03:59 PM
JadeDM's Avatar
yah i was just kinda nervous and im wondering why i was stupid and did that hehe. Thanks all for the help
Old Feb 15, 2004 | 04:06 PM
sumyungguy's Avatar
the computer usually doesnt allow it to cross over if the motor is cold
Old Feb 15, 2004 | 04:57 PM
IVI's Avatar
IVI
Default Re: Is it bad to vtec if your engine is cold? (sumyungguy)
yes it is bad. you should really baby your motor if you decide to drive it cold, or just let it warm up a few mins. you didnt bust anything or damage anything, but the mteal is all cold in ur engine. everything is made of metal/aluminum etc. there is anti-freeze and motor oil in ur engine obviously. motor oil when cold, isnt lubricative as its supposed to be. think about this, water for example, would be frozen at 32 or below. well your oil wont freeze, however it wont be thin and free thus not efficient as to where ur engine is at operating temp. a gradual warm up is required. metal expands and contracts with hot and cold.
Old Feb 15, 2004 | 05:52 PM
sickbling's Avatar
actually....V-TEC wont edgage unless you have enough oil presure..but no doubt its really bad if you hit VTEC and your oil isnt hot..therfore not protecting ur engine from wear...just dont do it anymore and youll be ok.
Old Feb 18, 2004 | 08:46 AM
mrmonk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadeDM &raquo;</TD></TR><TR><TD CLASS="quote">The other night i was leaving my friends house and it was a little chilly. I had been over there for about 4 hours so i dont know if my engine was still warm from earlier. I turned on the car for about 10-20 seconds then just vtec'ed it to redline in 1st and shifted into second. I dont know why i did it... but im just curious is it bad for the engine if its cold and i vtec it? Could i have busted something(internals valves etc.) punching it like that when the motor was cold?
Not a wise decision... At all. REDLINE for a B18C1 is not a problem, except when its cold. Reving you motor cold means your reving it with out the protection of oil through out your engine. This could mean metal rubbing against metal which = DISASTER. Let this be a lesson for you, i personaly dont ever rev my engine past 3.5 when it is cold. When i first start it in the winter i let it run for about 30-40 secs so the oil can get pumped slowly throughout the engine before i start driving.
Tam N
Honda Civic (2006 - 2015)
13
May 7, 2007 04:06 PM
teg969
Mar 22, 2005 03:14 AM
Drum_Guru
May 17, 2003 07:19 AM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
