BAD CAT!
Old Aug 12, 2003 | 06:34 PM
WhOIZiT's Avatar
Default BAD CAT!
so i found out i have a bad cat and thats why my cel light is on. now i need to know wat to do. i was told to get stock or new cat (thinking of Carsound), new o2 sensors (how many..2?)
now im just not knowing and dont know where to start and wat to do, any in depth info som1 can post so i know exactly wat to do and how much? do i need any gaskets in this case? how much do u think ill be spending?
Old Aug 13, 2003 | 04:25 AM
JimBlake's Avatar
Default Re: BAD CAT! (Turbonium)
It kinda depends on what year & model Integra you have. You must have OBD2 ('96+) otherwise the ECM doesn't know if the cat is working or not. You'll have 2 O2 sensors but maybe they're not bad.
Did you get the fault codes (check-engine-light codes)? That'll tell us a lot.
Old Aug 13, 2003 | 06:17 AM
Wraith_G2IC's Avatar
I may be no expert, but I can tell you that I have had no less than 5 Cats on my DA6. 1 OEM, 4 Aftermarket. OEM started to give higher emissions levels about 100K+ miles. The other 4 have all been Random Tech Cats. Why 4 you ask.... Broke 3 and 1 failed emissions after 2 years of use. All replaced under warranty since Random has a 5yr coverage. Many years ago it was $200+ for the Cat. I can tell you if the cat for your model is similar to mine (you didn't say which one you have) you will need only 1 gasket for the back. Where the cat fits to b pipe. For mine it is the same size gasket that fits on a Chevy V8 truck. Since I have changed several times I bought extras at Advance Auto Parts (aprox $1.50) by matching the opening on the new Cat. The front just slips over the header collector.
The only INSTALL problems I have had with the Random Tech part is the front flange bolt hole openings are not the right size for the oem Honda bolts on the DA. You need a Dremil or something similar to grind the holes larger to fit the Honda spring bolts. You can use straight bolts instead of oem, but they made the car vibrate more from the lack of flex like in the oem setup. I don't know, some people like it.
I don't remember about the o2 senson cost. That was replaced some time ago, but I do remember it was up there. I get oem parts from http://www.ahmotor.com . Cost less than the dealer. Shipping is low since I am one the East coast, and oem is almost always better than local parts shops parts.
Old Aug 13, 2003 | 06:31 AM
hondaboyturbo's Avatar
New User
Yea i agree that you have 2 o2 sensors , and as far as carsound goes they make good stuff check them out i think their units are around $100 or so , so worth a look. Peace
Old Aug 13, 2003 | 10:58 AM
Xumarius's Avatar
Default Re: (hondaboyturbo)
meow?
Old Aug 13, 2003 | 04:11 PM
WhOIZiT's Avatar
k i have a 01 gsr and im not sure wat kind fo cat i have currently, i know its not stock and i dont have the stock one. i wanna get the best cat that i wont regret and not really think about changing. so i know i have 2 o2 sensors, but im not sure if i need new cat or new cat and o2 sensors, sum1 just told me that i should get it anyways. the mechanic told me i just have a bad cat so i take it as that.
Old Aug 13, 2003 | 06:08 PM
JimBlake's Avatar
Default Re: (Turbonium)
I don't remember the error code #s at the moment, but...
If your mechanic read the error codes, there's one code that says something like "catalyst efficiency no good" and there's a different code that says something like "secondary O2 sensor malfunction". Maybe your car threw both codes, maybe only the catalyst code. We can't really answer which it is...
Old Aug 13, 2003 | 11:22 PM
XtremeCarTuner's Avatar
Default Re: BAD CAT! (JimBlake)
i think i have the same problem.. i'm throwing a P0420 i think on an OBDII
i think thats the engie code that i'm throwig... Is my cat bad too?
Old Aug 14, 2003 | 03:51 AM
JimBlake's Avatar
Default Re: BAD CAT! (XtremeCarTuner)
P0420 Catalyst System Efficiency Below Threshold
If that's the only code, then it looks like your cat.
Check out
https://honda-tech.com/zerothread?id=466877
That's Chiovnidca's post with a big list of all those codes. The secondary O2 sensor is kinda related to this, because that's what the ECM uses to decide if the cat is OK. If you get a code for the secondary O2 sensor, then you gotta decide if a screwed-up sensor is giving a false alarm about your cat.
Old Aug 17, 2003 | 10:52 PM
got any websites where i can find cats for a good price? I have a random technology cat, but i lost the warranty on it so scratch that idea of returning that back.i bought the cat from optionsauto.com....oh well
Old Aug 17, 2003 | 11:34 PM
timmy8151's Avatar
Get a Carsound from either:
http://www.ipsracing.com/engin....html
or
SMSP
It will cost about $180-$200 from each site, but you're going to get a cat that has the proper bungs and flanges in place.
Old Aug 18, 2003 | 01:59 AM
b18C1_liLkyLe's Avatar
i had the same problem. the cat might not be bad.. a simple reset of the ECU ( i think) will do the trick. and if not..yes new O2 sensors about $50 each give or take depending on how/where you get em and a after market cat is around a hundo like others have stated.
Old Aug 18, 2003 | 04:48 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeCarTuner &raquo;</TD></TR><TR><TD CLASS="quote">... I have a random technology cat, but i lost the warranty on it so scratch that idea of returning that back...</TD></TR></TABLE>
Call 'em & find out. They might have to honor the warranty anyway. Different states - different laws - I don't know how it works in CT.
ngengok99
Nov 28, 2012 02:41 AM
00_Civic_EX_Newb
40
Jul 22, 2008 07:55 PM
error
Sep 9, 2006 09:52 PM
mystikz2002
Sep 23, 2005 06:20 PM
Etylorcen
Jun 12, 2002 09:17 PM
