b20 with b16 head missing
Old Jul 5, 2008 | 08:19 PM
gundal's Avatar
Default b20 with b16 head missing
Have a b16a head on a b20b block, missing bad, compression tests results: 180 150 90 0 ( 1 2 3 4 respectively in honda order) any idea what compression leak could be or next step in diagnosing? Any help appreciated.
Old Jul 5, 2008 | 09:26 PM
hotrod99's Avatar
Default Re: b20 with b16 head missing (gundal)
sounds like you have some bent valves
Old Jul 6, 2008 | 11:31 AM
vtecb18c's Avatar
Default Re: b20 with b16 head missing (hotrod99)
or bad valve seals
Old Jul 6, 2008 | 12:03 PM
projectTeG's Avatar
Default Re: b20 with b16 head missing (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">or bad valve seals</TD></TR></TABLE>
i would like to know how bad valve seals could cause 0 psi. i would vote bent valves, damaged cylinder.
also have you looked at your coolant? oil? possible headgasket
Old Jul 6, 2008 | 12:04 PM
vtecb18c's Avatar
Default Re: b20 with b16 head missing (projectTeG)
my bad i thought it was 90 90..i read it wrong
Old Jul 6, 2008 | 01:37 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">my bad i thought it was 90 90..i read it wrong</TD></TR></TABLE>
90/90 would make me think blown headgasket
Old Jul 6, 2008 | 09:24 PM
gundal's Avatar
no oil in coolant or vice versa.
there is a large oil stain on the block under the head
did another test today and these were the results
dry (order 1,2,3,4 honda order)
160, 150, 60, 0
wet
190, 180, 90, 30
headgasket was a new cometic mls 84mm non vtec block to vtec head head gasket
used arp head studs and torqued down to proper specs
gonna have a differnt shop tear down the build tommorow and see whatsup
Fallriverb16
Sep 26, 2016 02:31 PM
si90rex
Apr 8, 2008 08:41 PM
91-lsvtecsi
11
Apr 28, 2006 03:12 PM
Dammit_Dan_954
Dec 9, 2003 01:56 PM
