B18B1 starting problems (please help)
Old Nov 3, 2009 | 08:43 AM
shekoski1213's Avatar
Icon2 B18B1 starting problems (please help)
Ok, so I was on my way to pick someone up when my car would not move when i hit the gas. Then it let out a backfire and cut off. Now when I try to start it, I hear a kind of sucking noise. Like at the intake filter trying to suck something up. It trys to start but still makes the noise and stops. My first guess was no spark, maybe a bad coil. However, there is a spark. Hopefully someone on here has experienced this problem and can help me. Thanks for taking a look.
Old Nov 3, 2009 | 11:13 AM
weavertime1's Avatar
Default Re: B18B1 starting problems (please help)
Take a look at your timing belt just to make sure you didn't jump time or snap a belt. Tough to tell with the vague description. Good luck!
Old Nov 3, 2009 | 11:16 AM
QuikSilverTeg's Avatar
Is it throwing any CELs? Can you hear the fuel pump prime when you turn the Key to "On?"
Old Nov 3, 2009 | 12:50 PM
Turbo-LS's Avatar
sounds like it jumped a tooth on the belt or your fuel filter is clogged
Old Nov 3, 2009 | 05:40 PM
thanks for the suggestions guys.
Old Nov 4, 2009 | 03:08 PM
God-Driven's Avatar
I had the same problem with my it end up been the ignition rotor inside the cap, the bolt came loose and it was showing spark but it wasnt been deliver on time, also like the other guys said check the timing marks but pull the cap off and check the rotor thats a lot easier to do, if theres no fuel most likely is going to be the main relay 9 out of 10
Old Nov 4, 2009 | 04:20 PM
plenty of fuel....ive heard about that....are you talking about where the plugs go?
Old Nov 5, 2009 | 01:56 PM
God-Driven's Avatar
The ignition rotor is inside the dizzy, just take off the cap and make sure the rotor its tight and that the bolt is in there
Old Nov 8, 2009 | 07:52 AM
bump. The car makes a pop noise when starting then winds down?
Old Nov 8, 2009 | 08:18 AM
Turbo-LS's Avatar
just fix the fuel problem first then try with the starting and spark man
Old Nov 8, 2009 | 10:55 AM
problem fixed. it was the bolt in the dizzy. thanks guys.
peAches yO
Apr 29, 2011 09:52 PM
paowa
Feb 4, 2009 10:38 PM
the soL that could
11
May 30, 2006 07:58 AM
beauduvall
Feb 10, 2004 09:05 AM
IgniteTeg
21
Sep 14, 2003 06:47 AM
